ᐅ How can I build Ikea Besta as a multifunctional storage solution?
Created on: 5 Apr 2020 10:12
Logu65
Logu65
5 Apr 2020 10:12
Hello everyone, I am planning to build a multifunctional storage solution using the Ikea Besta system and am looking for tips and suggestions. Specifically, I am interested in how to combine and modify the Besta units to serve different storage purposes—such as for books, electronic accessories, and possibly as a small workspace or display area. Ideas for suitable modules, useful accessories (e.g., doors, drawers, inserts), and practical modifications are very welcome. It would also be great if anyone has experience with a sturdy construction that not only looks good but remains durable under load. Thanks in advance for all your suggestions!
BOSULE
5 Apr 2020 11:45
A project like this should be carefully planned, especially when integrating multiple functions. My advice is to start with basic modules in standard dimensions, as these offer the greatest flexibility.
- Combine open compartments and closed doors to ensure both visibility and organization.
- Use adjustable shelves suitable for the intended storage height, for example for books or equipment.
- For technical accessories, consider interior fittings with cable outlets and possibly small boxes.
Be sure to check the load-bearing capacity of each part, especially if you plan to integrate heavy equipment. Stability can be improved with back panels or additional connectors.
Kolepau
5 Apr 2020 12:30
Super interesting topic! I designed my cabinet so that it has drawers at the bottom for cables and electronics, and open shelves at the top for decorations and books. 👌😃
It’s best to create different modules, this gives you maximum flexibility! You can skip doors or use glass doors — it looks really elegant and still protects against dust. And don’t forget: enhance it with LED strips – they add a great atmosphere!
kla69
5 Apr 2020 14:07
Logu65 schrieb:
Specifically, I am interested in how to combine and modify the Besta system to serve various storage purposes – for example, for books, tech accessories, and possibly as a small workspace or display area.
To provide truly customized recommendations, it would be helpful to know the exact amount of storage needed and which specific devices or items should be integrated. For instance, for electronics, cable management systems and ventilation openings are advisable, especially for media equipment.
A layered design with varying depths can be practical:
- Depth of 40 cm (16 inches) for books
- Depth of 20 cm (8 inches) for smaller devices
- Shelving with removable inserts for displays
Regarding stability: Make sure to use appropriate screws to secure the top and bottom units, possibly reinforced with metal brackets. If you plan to use it as a workspace, consider stronger worktops or additional braces.
BeAndrea
6 Apr 2020 09:25
Hello! I have already put together several Besta systems and find it very helpful to first clarify which functions the individual compartments should actually serve.
If you want to store technical accessories, for example, you can use simple plastic boxes or inserts that can be arranged individually – this way you keep an overview and can store cables neatly.
For use as a work surface, I would suggest placing a sturdy, slightly thicker panel on top. Ikea offers good surfaces for this that are easy to install. Doors with soft-close hinges add a more premium feel.
I also recommend assembling the individual modules online or in the furniture store before purchasing – this way you can better estimate how they will fit together.
One more tip: Besta systems with glass fronts make the shelves appear more open, while allowing you to display and protect decorations or books at the same time.
Tevin
6 Apr 2020 14:37
A practical multifunctional solution should also facilitate easy access. Drawers with dividers are ideal for neatly storing small items like cables, adapters, or pens.
Adjustable-height shelves are convenient for books, allowing different sizes to be accommodated efficiently.
If you want to use the Besta as a small workspace, a sturdy clamp lamp or lighting above the unit can enhance its functionality.
Consider open compartments to keep frequently used items quickly within reach.
