ᐅ How can I build Ikea BESTA as a custom-made furniture piece for sloped ceilings?
Created on: 9 Sep 2019 18:27
Sandro33Hello everyone,
I am planning to build a custom piece of furniture using Ikea’s BESTÅ system to fit under a sloped ceiling and am looking for specific recommendations and practical experiences. The challenge is that although Ikea’s standard furniture is modular, it is not necessarily designed for angled walls. I would like to know the best ways to modify the BESTÅ components, for example, whether cutting the cabinet sides or special mounting solutions are needed, and what to pay particular attention to regarding stability and appearance.
Has anyone here completed similar projects or can offer tips on how to ideally integrate the sloped ceiling without damaging the furniture or making the process unnecessarily complicated?
I would really appreciate your advice, ideally with concrete implementation suggestions, tool recommendations, or which parts from the BESTÅ range work best.
Thanks and best regards!
Sandro33 schrieb:
I would like to know the best way to modify the BESTÅ units, for example whether cutting the cabinet sides or special mounting options are needed, and what to pay special attention to regarding stability and appearance.That’s a very good approach; I tried the same method myself. The real challenge is the sloped ceiling because adapting the sides to the angled walls was the problem for me. I even borrowed a jigsaw to cut the side panels to fit, which worked well, but I was uncertain whether the stability would be compromised.
It was important to carefully sand and seal the cut edges afterward to protect the wood from moisture.
In addition, I used corner brackets to keep the furniture firmly and securely assembled, which especially helps with stability on the sloped walls.
If you’re unsure, it’s worth first making a detailed sketch, measuring accurately, and marking the slope on the wall with painter’s tape to create paper templates to check the dimensions.
I hope this helps—you sometimes need some patience, but in the end, it’s really satisfying when you manage to integrate the slope well.
Sandro33 schrieb:
Has anyone here completed similar projects or have tips on how to integrate a sloped ceiling ideally without damaging the furniture or making the process unnecessarily complicated?Hey Sandro33!
What an exciting project! Adding a bit of DIY spirit really personalizes IKEA Besta furniture.
I wanted to share a tip that helped me with fitting: use a shadow gap along the top edges of the furniture, meaning leave a small air gap (~5 mm (0.2 inches)) between the cabinet and the sloped ceiling. This makes the edges look more professional and prevents the furniture from getting stuck or jammed due to temperature changes.
Also, using hidden mounting brackets on the wall helps keep the cabinet stable and prevents it from wobbling. If you clamp wooden strips behind the back panel, you can also adjust the back panel without fully cutting it.
From my experience, fitting the BESTÅ system was quite manageable if you measure carefully and have a bit of patience. I’d be interested to hear how your build progresses!
Franz schrieb:
I specifically borrowed a jigsaw to cut the side panels to size, which worked well, but I was also unsure whether this would affect the stability.An important consideration when adapting the BESTÅ units to sloped ceilings is that cutting side or back panels can compromise the original factory stability. The BESTÅ series is modularly designed, but the system is not intended for angled modifications, which requires additional reinforcement measures.
Here are some practical tips:
- All cut edges should be properly sealed to prevent moisture damage.
- The furniture units should be additionally stabilized on the inside with angle brackets or metal corner braces.
- Back panels can often be replaced with partial sections to fit the slope. It is beneficial to create back panels with cutouts or angled cuts, provided they still offer sufficient stability.
- For a perfect fit, precise measurements are recommended, and if necessary, making a paper template of the slope.
Furthermore, it should be considered that installation on sloped ceilings sometimes requires additional anchoring to the wall and floor to prevent tipping, especially when the furniture is fully loaded.
This approach has proven successful in multiple projects and can be carried out using standard tools. Custom-made side panels are advisable when the standard units cannot be properly cut to fit.
