ᐅ How do I build an IKEA Metod kitchen with plenty of storage in a small space?
Created on: 16 Nov 2020 08:17
arvidleo32
Hello everyone, I’m currently planning my new kitchen and have decided on the Ikea Metod system. Now I’m facing the challenge of designing a functional Metod kitchen with as much storage space as possible, even though the room is very limited. Specifically, it’s a small kitchen area of about 3 meters (10 feet) in length and 2 meters (6.5 feet) in width, with corners that are quite tight. I want to make optimal use of both wall cabinets and base cabinets to maximize storage without making it look cluttered. Has anyone had experience with making the most of storage space in such a small area? Are there particular modules, pull-outs, or combinations that work especially well in compact kitchens? I’m also interested in any tips that can make installation easier or visually create the impression of more width or depth. Thanks in advance for any helpful advice or suggestions!
gadalu
17 Nov 2020 11:14
arvidleo32 schrieb:
What exactly do you mean by "full-extension slides and inner drawers"?
Full-extension slides are drawer systems that allow the entire drawer to be pulled out, providing unrestricted access to the back. Inner drawers (also called inner containers) are smaller compartments within the main drawer. They improve organization and storage efficiency and are often used for cutlery or small kitchen appliances.
arvidleo32 schrieb:
The "Magic Corner" sounds interesting, but I’m a bit worried it might be cumbersome with daily use.
The Magic Corner is especially useful in tight kitchens where corner spaces would otherwise be impractical. It is sturdy, but if you frequently need quick access to items in the corner cabinet, the mechanism can take some getting used to at first. An alternative would be Le Mans systems, which operate similarly but are somewhat easier to handle.
Regarding the wall cabinet: mounting it up to the ceiling maximizes storage space, but a step stool or small ladder should be available to reach the upper shelves. Items used regularly should still be stored in the lower sections.
nedagla
17 Nov 2020 15:02
gadalu schrieb:
The Magic Corner is especially useful in tight kitchens where corners would otherwise be impractical. It is sturdy, but if you need frequent quick access to items in the corner cabinet, the mechanism might take some getting used to at first.
I can confirm this! 😊 After getting used to it, the Magic Corner is very practical. Just plan everything carefully from the start, and assembling it will be much more enjoyable. For the Metod system, I would definitely recommend full-extension drawers and good internal organization, as that also makes using the space more comfortable, even in small kitchens!
Layla
18 Nov 2020 08:06
I wanted to add: Especially when space is limited, ergonomics can quickly become a challenge. When planning, consider how often you use different items and store those you use frequently in easily accessible areas. For example, in my kitchen, I keep all the essentials in lower drawers with full extensions, as I find that more comfortable than upper cabinets.
arvidleo32 schrieb:
Is it practical to build these cabinets all the way up to the ceiling, or does that quickly become inconvenient?
I built mine almost up to the ceiling but only use the top space for seldom-used items. Important: A sturdy step stool is a must. Maybe you can combine wall cabinets so that not all of them reach the ceiling, just part of them, to avoid having to climb all the time.
glamo
18 Nov 2020 12:27
In addition to my previous comments: I recommend measuring the exact dimensions of all your kitchen utensils (pots, pans, plates) and food supplies before finalizing the design. This will help you better determine which types of cabinets and interior fittings you will need.
- For your appliance planning: take into account the standard built-in dimensions, especially the panel height below the appliances, to avoid losing storage space.
- Metod offers the option to install so-called “cabinet towers,” which provide maximum storage space even in small areas – for example, for spices or narrow bottles.
- I also suggest choosing clear and easily visible doors for the wall cabinets. Glass fronts with shelves can create a sense of openness.
Regarding your question about the Magic Corner: it is useful if you need a lot of storage in the corner. If you rarely have corner cabinets, you can use the space differently with tall cabinets.
I would be interested to know the height of your room to better assess the wall cabinet planning. How high is your ceiling? Do you have a standard ceiling height of 2.40m (7 ft 10 in) or higher?
