ᐅ How can I build an Ikea Metod kitchen with plenty of countertop space?
Created on: 4 May 2021 09:13
lenri
I am planning to build my new kitchen using the Ikea Metod system and want to maximize the usable countertop space. My kitchen is about 3.5 meters (11.5 feet) wide and 2.8 meters (9.2 feet) long, with a layout resembling a simple straight line plus a peninsula. I am especially interested in how to choose and arrange the modules most effectively to achieve a generous work surface without significantly reducing storage capacity. Are there specific combinations of base cabinets that provide a lot of surface area? Or tips on integrating countertop materials and add-on modules to create even more space? I would also like to know if there are any useful tricks for installation that I, as a beginner, should be aware of to ensure the result is as level and stable as possible. I look forward to your experiences and practical advice!
RETRAVIS
4 May 2021 16:21
Regarding height differences with Metod modules: Ideally, all base cabinets should be of the same type and depth to ensure a consistent height. Ikea offers its standard modules with a depth of 60 cm (24 inches), as well as 37 cm (15 inches) for tall unit variants.
Combining different depths makes it difficult to have a continuous countertop, as heights and fronts will no longer align flush. Therefore, I recommend:
- A uniform depth of up to 60 cm (24 inches) for base cabinets
- Avoid variations in the toe-kick height; Ikea cabinets have adjustable feet that should be carefully set
- Consider the thickness of the countertop: the thicker it is, the better it resists sagging and the more appealing it looks
If you are building a peninsula, make sure the countertop is cantilevered and well supported to avoid stress. Mounting brackets or additional panels can be helpful for this.
bapar
5 May 2021 09:17
A few more technical details regarding installation and countertop adjustment:
- Countertops from Ikea often come in standard lengths. Make sure to measure your room dimensions precisely before placing an order.
- For corners or transitions at the peninsula, you may need to cut and fill the countertop yourself.
- For longer countertops, use additional support beams (mounting brackets or wooden strips) to prevent sagging.
- Be careful with connections: water and electrical outlets must be carefully planned before assembly; the cabinets are standardized, but installation can become challenging if not well thought out.
If you decide to install the countertop seamlessly over two or three cabinets, you can stabilize the modules further with precise connectors. I can provide advice on specific materials or bending radii of the countertop if needed.
neoren
5 May 2021 11:04
To maximize workspace, I would recommend the following points:
- Choose wide base cabinets
- Avoid gaps caused by sink cabinets whenever possible
- Secure the countertop well, especially for islands
When purchasing, keep an eye on the height of the legs to ensure everything is at the same level.
