ᐅ How can I build an Ikea Metod kitchen with plenty of countertop space?
Created on: 4 May 2021 09:13
lenri
lenri
4 May 2021 09:13
I am planning to build my new kitchen using the Ikea Metod system and want to maximize the usable countertop space. My kitchen is about 3.5 meters (11.5 feet) wide and 2.8 meters (9.2 feet) long, with a layout resembling a simple straight line plus a peninsula. I am especially interested in how to choose and arrange the modules most effectively to achieve a generous work surface without significantly reducing storage capacity. Are there specific combinations of base cabinets that provide a lot of surface area? Or tips on integrating countertop materials and add-on modules to create even more space? I would also like to know if there are any useful tricks for installation that I, as a beginner, should be aware of to ensure the result is as level and stable as possible. I look forward to your experiences and practical advice!
RETRAVIS
4 May 2021 10:27
Building an IKEA Metod kitchen with plenty of countertop space requires careful planning when selecting cabinets and work surfaces.
- Use wide base cabinets, for example 80 or 90 cm (31.5 or 35.5 inches) instead of 60 cm (23.5 inches), to create more continuous surface area.
- Minimize divisions with sink or cooktop modules, as these reduce the uninterrupted workspace.
- Choose a high-quality, thicker countertop (at least 30 mm (1.2 inches)) that is stable and durable.
- Ensure a sturdy substructure and secure fastening of the modules to prevent the countertop from sagging.
During installation, it is important to align the walls precisely. If there are irregularities, use shims to bring all cabinets to the same height. Finally, cut the countertop accurately or have it cut by IKEA.
bapar
4 May 2021 11:09
Regarding the countertop surface in the Ikea Metod kitchen, I would like to provide a more detailed explanation, as the topic involves several aspects.
First, the choice of cabinet types: For maximum countertop space, it is advisable to select many wide base cabinets without internal dividers, for example, 80 or 100 cm (31 or 39 inches) wide cabinets. Another tip is to replace the standard sink cabinet with an integrated cutout in the countertop or to plan a separate sink island if the room allows.
Furthermore, continuous installation of the countertops is crucial. If possible, the countertop should span multiple units with as few seams as possible. Ikea offers countertop coverings made of various materials – solid wood, high-pressure laminate (HPL), or laminate. Those who choose solid wood should be aware of its sensitivity to moisture and the need for regular maintenance.
Regarding installation, I strongly recommend aligning and leveling all cabinets precisely before mounting the countertop. Even slight unevenness can cause the countertop to warp or rest unevenly. Additionally, I advise securing the countertop from underneath at several points with screws to prevent sagging.
If you have specific room dimensions or usage profiles, I’m happy to assist with the planning.
dosogau
4 May 2021 11:44
Use wide base cabinets and allow the countertop to overhang. Avoid sink modules if possible, as they reduce the usable surface area. Secure the countertop firmly to prevent sagging.
nanidra
4 May 2021 12:15
Why have so much work surface? Most of the time, a lot of stuff just ends up sitting around and you don’t use the space fully. Better to have less surface and more storage. With Metod, the storage options vary, but I think that’s the most important thing. A large countertop alone doesn’t make a kitchen better.
lenri
4 May 2021 14:03
nanidra schrieb:
Why have so much countertop space? Usually, it just ends up cluttered and isn’t fully used.
That’s generally true, but it’s different for me: I spend a lot of time working in the kitchen, including baking and preparing larger meals. A generous, well-designed workspace greatly improves workflow, especially when handling multiple tasks at once.
RETRAVIS schrieb:
Use wide base cabinets, for example 80 or 90cm (31½ or 35½ inches) instead of 60cm (24 inches), to create more continuous countertop space.
Thanks, that’s helpful. Are there specific cabinet combinations that are particularly shallow to ensure the countertop lies as flat as possible, without height differences? I’ve heard that with Ikea there are structural factors that can make this challenging.
bapar schrieb:
If you have specific room dimensions or usage profiles, I’m happy to help with planning.
I’d gladly take you up on that. My floor plan is—as mentioned—3.5 x 2.8 meters (11.5 x 9.2 feet), with one run along a wall plus a peninsula about 120cm (47 inches) long and 60cm (24 inches) wide.
