ᐅ How do I build an Ikea Metod kitchen island with additional storage?
Created on: 16 Aug 2017 09:12
sarfinn
Hello everyone, I am planning to build an Ikea Metod kitchen island that will provide extra storage in addition to the usual countertop workspace. I want to make the most of all available module widths to combine drawers and pull-outs in the best possible way. It is important to me that the construction is stable and can also accommodate additional kitchen utensils that would normally be stored in cabinets. Has anyone had experience assembling such islands and can share tips on which modules work particularly well, which adhesives or joint methods are recommended, and how to best stabilize the kitchen island? If you also have suggestions on how to use the storage space ergonomically, I would be very happy to hear your advice!
pautanner17 Aug 2017 10:41So, if you ask me, a bit of coolness in the form of recessed casters (lockable!) not only adds flexibility but can also make the island more accessible if you ever want to remodel. Just be sure to use sturdy brakes!
And after the entire assembly, don’t forget to add a nice countertop. It not only looks good but also provides the necessary support under load.
keogla schrieb:
If there is no wall nearby, it helps to design the countertop with an overhang and reinforce it inside with sturdy metal brackets. Sounds like a smart solution. How strong should the brackets be? Do you have any dimensions or recommendations?
kla65 schrieb:
Definitely use a cordless screwdriver with torque control for assembly. I agree. I will implement that. Thanks to you all in advance!
The brackets must be at least 3 mm (1/8 inch) thick; stainless steel is preferred because it is corrosion-resistant. I personally used 40x40 mm (1 5/8 x 1 5/8 inch) brackets, which are sturdy and easy to install. During installation, I recommend clamping all modules together with spring clamps before screwing them in, to ensure proper alignment.
For the countertop: solid wood with an oiled finish is particularly easy to maintain and tolerates minor scratches. If you prefer stone, be sure to have a solid substructure due to the weight.
