ᐅ How do I build an Ikea Metod kitchen island with an integrated seating area?
Created on: 26 Jan 2020 09:17
shamsul
I am planning to build an Ikea Metod kitchen island with an integrated seating area but I’m still unsure about the best way to approach it. Specifically, I want to create a kitchen island that offers storage space as well as a seating area for at least two people—ideally with bar stools.
My question is: How do you build an Ikea Metod kitchen island with an integrated seating area? Which modules are best suited for this, how should the design ensure stability and efficient use of space, and are there any practical tips on how to integrate the seating surface effectively (e.g., height, material adjustments, connecting the modules)? I’m also interested in how you handle the countertop and attaching the seating area to the kitchen island to ensure both are stable and visually appealing.
Thanks a lot for your help and experience!
O
onMarcos
27 Jan 2020 11:59
Hello shamsul,
Here is a simple step-by-step guide on how I built my Metod kitchen island with a seating area:
1. Planning: Choose kitchen cabinets with the correct depth (80 cm (31.5 inches)) and height (88 cm (34.6 inches) without legs).
2. Base frame: Securely connect the modules using the supplied connecting fittings. Additionally, I placed the modules on a plywood base panel for extra stability.
3. Worktop: Install the standard kitchen worktop at about 90 cm (35.4 inches) height.
4. Build the seating area: You will need a second, raised worktop (about 15 cm (6 inches) higher than the main worktop), which is attached to the side of the island using heavy-duty metal brackets. Make sure to fasten the brackets over a wide area (using Spax screws into the wood).
5. Seating area size: Plan for an overhang of at least 30–40 cm (12–16 inches) to allow enough knee clearance.
6. Finishing: You can protect the seating surface with edge bands to keep the worktop looking good for a long time.
Mistakes to avoid: Using cheap screws or brackets that are too small. It is also important to cut the worktops precisely to prevent unsightly joints.
I hope this helps you!
Tatovin
27 Jan 2020 14:45
Attach the countertop with strong metal brackets so that it overhangs.
Seat height approximately 105cm (41 inches).
Ensure the stability of the modules with connector fittings.
Material selection: Solid wood lasts longer than MDF.
miAlessio
28 Jan 2020 09:03
In addition to the previous discussion, here are a few more tips:
- Ideally, use a worktop with a thickness of 3-4 cm (1¼–1½ inches) for the seat surface, which you can cut to size.
- For added comfort, you can create a slight overhang (about 5 cm / 2 inches) at the bottom edge of the seat surface, making cables or expansion gaps less visible.
- Screws fastening the worktop to the base cabinets should be secured with appropriate wall plugs or anchors to ensure durability.
- If you plan to place bar stools underneath, allow sufficient width per seat (at least 50 cm / 20 inches).
- Matching the color of the worktop and base cabinets creates a visually harmonious overall look.
I also recommend preparing a sketch or CAD plan beforehand to ensure precise measurements.
retau
28 Jan 2020 12:22
shamsul schrieb:
Do you know how you attached the raised countertop? Are standard shelf brackets enough, or did you use special supports?
I used sturdy L-brackets on my island, much stronger than regular shelf brackets! 👍 If you want the seating area to be really stable, it’s better to play it safe.
hauklo schrieb:
The material and design of the countertop should match, for example, solid wood or a laminated surface.
Exactly, I would never use MDF for the seating surface—opt for solid wood or a solid surface material instead.
Make it cozy with nice bar stools—that’s definitely motivating! Good luck with your build!
Khalil
29 Jan 2020 08:56
I used extra-strong metal brackets, and they hold really securely! I wouldn’t recommend regular shelf brackets, as they are often too weak to support the weight when sitting.
Also, I made both the seat surface and the countertop from the same solid wood, which looks much more cohesive!
Don’t worry, as long as everything is measured accurately and screwed in with enough support points, it works great!
