ᐅ How do I build an Ikea BESTA wall unit with customized lighting elements?
Created on: 9 Oct 2020 19:37
Petrit
Petrit
9 Oct 2020 19:37
Hello everyone, I am planning to assemble an Ikea BESTÅ wall unit and would like to add custom lighting elements. I feel fairly confident about the basic assembly, but I have concerns about integrating lighting, especially LED strips or spotlights, regarding the wiring, power supply, and how to make the connections as discreet as possible. Maybe someone has experience with how to mount the light strips so they don’t interfere with the storage space, and how to best set up the electrical circuit (e.g., using outlets, laying cable ducts, or even installing switches within the wall unit). I am also interested in whether there are practical solutions for dimmable lighting systems that work well with the BESTÅ system, particularly in terms of safety and ease of use. I look forward to detailed advice on how to build everything neatly and functionally.
Rodolfo
9 Oct 2020 20:03
Regarding the Ikea BESTÅ wall unit with custom lighting elements: The BESTÅ system, with its modular cabinets and back panels, is generally well suited for installing LED lighting. For installation, I recommend: - Cut or remove sections of the back panels as needed to allow cables to pass through. - Attach LED strips preferably to aluminum profiles to dissipate heat and extend their lifespan. - Position power outlets behind or next to the wall unit and use cable ducts at junctions to conceal wiring. - Use flexible 12V power supplies commonly used for LED strips, as they are safer than 230V lines and easier to integrate. - Dimmers can be installed as inline switches between the power supply and the LED strip, but wireless systems are also available for convenient control. It is important to design the circuit to allow easy maintenance and future expansions. For safety: All work involving mains voltage should be carried out only by qualified personnel, otherwise it is better to use ready-made plug-and-play LED lighting solutions. Overall, this is technically feasible, provided a cable plan is prepared in advance and suitable components are sourced.
Luciandi
10 Oct 2020 07:52
[@quote=Rodolfo, post: w8u1y7, member: XXX]"It’s best to mount LED strips on aluminum profiles to dissipate heat and extend their lifespan."[/quote]
I can only agree with that! I installed LED strips on my BESTÅ wall unit and was really surprised how much the aluminum profile helps with heat management. At first, I was unsure if I could handle it on my own, but with some patience, it went quite well.
[@quote=Petrit, post: p5p3j5, member: XXX]"I would like to add custom lighting elements [...] especially when integrating lighting, particularly LED strips or spotlights [...] how to make the wiring as discreet as possible."[/quote]
What helped me was making sure to run the cables along the backs of the frames during assembly and securing them with cable clips or small zip ties. This looks neat and doesn’t interfere with storage space. I also recommend creating a small cutout or hole—if possible—for the cable end. For power, I use power strips behind the wall unit, which I operate via a switch.
I know the beginning feels a bit complicated, especially regarding cable management, but I think the effort is worth it since the lighting really enhances the atmosphere of the BESTÅ and also offers practical advantages when searching for items. Petrit, I’m happy to share my experience if you like!
Jaime
10 Oct 2020 12:16
In addition to the previous explanations: A practical and safe solution for integrating LED lighting into the Ikea BESTÅ wall unit is to use 12V LED systems with a separate power supply. This significantly reduces the risk of electric shock and allows flexibility by using thinner cables.
- I recommend choosing LED strips with sufficiently bright output (at least 3000 Kelvin, 800-1000 lumens/meter (240-305 lumens/foot)) to ensure the lighting feels warm white and inviting.
- The adhesive tapes provided are often insufficient for mounting on wood surfaces; aluminum profiles or additional fasteners are helpful here.
- Especially with dimmable systems, it’s important to ensure that the power supply, dimmer, and LED strips are compatible to prevent flickering.
- Switches can be integrated directly into the wall unit or operated wirelessly, the latter minimizing installation effort.
- Plastic cable ducts are ideal for hiding cables, but make sure they are securely fastened and discreetly routed.
In general, planning the exact position of the cabinets and electrical components before installation ensures a smooth setup.
