ᐅ How can I build an IKEA Besta unit as a multifunctional cabinet with adjustable compartments?
Created on: 25 Jun 2021 18:43
trapau
trapau
25 Jun 2021 18:43
I am currently planning to design an IKEA Besta cabinet to be as multifunctional as possible, with adjustable compartments that can easily adapt to different needs.
I am particularly interested in how to assemble and modify the modules so that books, decorations, electronic devices, or even clothing can fit inside as needed.
Are there any proven tips for combining different compartment sizes and possibly installing additional elements like drawers, flip doors, or dividers? I would also like to know how to set it up so that I can easily make adjustments later if the usage changes, without having to rebuild everything from scratch.
I look forward to your experiences and advice, especially if you know of any specific techniques that make remodeling easier or increase stability for variable use.
Thank you in advance!
LANICOLE
25 Jun 2021 20:29
Hello trapau,
First of all, I think it’s great that you want to use the IKEA Besta as a multifunctional cabinet. The flexibility of this system is definitely one of its biggest advantages. Here is a brief guide on how you can proceed:
- Start by selecting the base modules according to your space requirements and intended use. Besta comes in different heights and widths – the most common modules are 64x64 cm (25x25 inches).
- For adjustable compartments, I recommend using the adjustable shelves. IKEA offers different shelf boards that allow you to change the height of the compartments at any time.
- For more functionality, drawer boxes from the Besta series can be easily integrated into a module. This gives you flexible storage for small items.
- You can also combine flap doors or regular doors depending on how you want to use the cabinet, so some compartments remain open while others are closed.
- If you want to accommodate devices like receivers or consoles, consider ventilation and cable management. Some users create small cutouts or leave the back panel open.
- Stability is important with flexible use: it’s best to screw the modules together and attach them to the wall to prevent tipping.
- If you want to modify the setup later, the shelves and fronts are modular enough to adapt the system.
Common mistake: many underestimate wall mounting. Even if the cabinet stands firmly, securing it to the wall prevents tipping, especially when using heavy equipment.
Summary:
- Choose the right base module
- Use adjustable shelves
- Add drawer boxes
- Combine open and closed compartments
- Provide ventilation for electronics
- Screw modules together and secure to the wall for stability
I hope this helps you get started!
tarju41
26 Jun 2021 07:52
LANICOLE schrieb:
For more functionality, drawer boxes from the Besta series are recommended, which you can easily integrate into a module.
Exactly, drawers make the system flexible. With different compartment heights as well, everything fits perfectly.
LANICOLE schrieb:
It’s best to screw the modules together and secure them to the wall to prevent tipping.
Absolutely. Safety comes first, especially with variable use.
FLOBAU
26 Jun 2021 16:34
To add to this, I would like to provide precise advice on how to optimally assemble the IKEA Besta as a multifunctional cabinet with adjustable compartments:
1. Modular Planning: Combine different module depths (30 cm (12 inches) and 40 cm (16 inches)) within your cabinet so you can create versatile storage for various items such as books, electronics, or larger objects.
2. Adjustable Shelves: Be sure to use the included metal rods for the shelves, which allow for stepped height adjustments in increments of 3.2 cm (1.25 inches). This way, you can customize the shelf heights precisely according to your needs.
3. Interior Fitting: For electronic devices, it is recommended to invest in special perforated panels or cable grommets from the accessories to neatly route cables and ensure adequate ventilation.
4. Front Design: To keep the cabinet multifunctional, a combination of open compartments, closed doors, and drawers is advisable. This provides both easy accessibility and protection from dust.
5. Stability: IKEA provides sturdy connectors for the Besta series that you should use to screw the individual modules together. Additionally, wall mounting is mandatory to ensure stability—especially when repurposing or under variable loads.
6. Expandability: Since the system is based on standardized modules, you can easily add more units or replace existing ones later on.
An important tip: When choosing hinge and door types, make sure they fit your usage habits—for example, soft-close hinges for frequently accessed compartments.
By following these methods, you can adapt your Besta cabinet flexibly and functionally to different requirements without having to carry out major modifications.
