ᐅ How can I best use Ikea PLATSA for small spaces?
Created on: 10 Dec 2020 08:36
Minel
Minel
10 Dec 2020 08:36
Hello everyone, I am currently considering how to use the Ikea Platsa system as efficiently as possible in very small rooms. My room is about 9 square meters (97 square feet), and I want to create storage without making the space feel cramped or impractical. I am especially interested in tips for the optimal combination of wall cabinets, base units, and drawers. Are there specific layouts or module sizes that work particularly well for small areas? I would also like to know how to best plan the system when both open and closed storage options are needed. Has anyone had experience adapting PLATSA flexibly to changing needs in a small space? I look forward to constructive ideas and possibly technical details to better understand what to pay attention to.
minan
10 Dec 2020 10:48
The question is very well posed and brings up important points regarding space optimization with PLATSA. As a general recommendation, first measure the room accurately and create a detailed sketch, marking doors, windows, and any radiators or electrical outlets.
- In small rooms, it is especially important to consider the depth of the units: PLATSA offers many modules with a depth of 35 cm (14 inches), which is better suited for tight spaces than the deeper options (55 cm / 22 inches).
- Additionally, narrow, tall cabinets are often more advantageous than wide, low ones because they make use of vertical storage space and save floor area.
- For flexible layout, I suggest mixing open shelving with closed units to balance accessibility for everyday items and a tidy appearance.
Another important tip: place modules with drawers or doors where you can easily reach them, as the limited space can sometimes restrict movement.
I’m curious: How high is your ceiling? Are there any specific items you definitely want to accommodate? With such additional details, I can provide more precise technical recommendations.
Ianlau
10 Dec 2020 12:22
Regarding PLATSA in small spaces, I would like to add: The modularity of the system plays an important role. The individual components can be easily connected and reconfigured. This is ideal if you want to stay flexible in the long term.
- My advice is not to overfill individual modules, as this can quickly make the space feel cluttered.
- Use wall cabinets especially above less frequently used areas such as work surfaces or beds, so the floor wall space remains free.
- If you like, use cabinet doors with mirrors to create a visually larger effect.
In addition, PLATSA offers various color and material options for doors and fronts that you can choose from. Light colors help to avoid a cramped feeling in small rooms.
JAFUHAU
11 Dec 2020 09:07
minan schrieb:
I’m curious: How high is your ceiling? Are there specific items you definitely want to fit in?
That’s a really interesting question, because ceiling height often matters more than you might think. I had a very small room myself with a ceiling height of 2.4 meters (7 ft 10 in) and was able to make great use of vertical space with the PLATSA system. However, at first, I didn’t consider that I’d need easy access to the upper compartments—a step stool or small ladder is definitely necessary.
It was important for me to store books, folders, and some clothing. I also wanted a mix of open and closed storage because I need both for everyday use: open shelves for newspapers and frequently used items, and closed compartments for less attractive daily clutter.
Planning takes some patience, but I’m very happy with PLATSA because it offers not only practical but also visually flexible solutions.
Juan31
11 Dec 2020 14:15
Minel schrieb:
Are there specific layouts or module sizes that work particularly well for small spaces?
The most practical answer: Yes. For small rooms, PLATSA units with a depth of 35 cm (14 inches) are better suited than the standard 55 cm (22 inches). This reduces the floor footprint and allows for more free movement.
Regarding layout:
- Tall, narrow units (e.g., 30 cm (12 inches) wide and about 198 cm (78 inches) high) offer a space-saving option while providing significant storage capacity.
- Combining open shelves with closed cabinet doors creates a good balance between visibility and tidiness.
- The flexibility of PLATSA also comes from the ability to stack the modules or place them side by side.
In my view, using the space near the ceiling is also important. Since small rooms are often furnished simply, the top modules can be reserved for items that are rarely used.
A practical tip: Choose materials or colors that visually harmonize the space, such as light or uniform fronts.
faso31
12 Dec 2020 08:03
Ianlau schrieb:
Modularity plays an important role in the system.
That is generally true, but I would like to add a critical point: PLATSA is often promoted as a cure-all for small spaces, yet its flexibility comes with some limitations.
For example, the stability of the modules decreases when stacking them too high or attaching them to weak sections of the wall. This should definitely be taken into account during planning.
Additionally, I recommend carefully planning the space in terms of traffic flow. Sometimes, a combination of narrow, tall shelves with some custom-made elements (not necessarily PLATSA) makes more sense—especially for difficult corners or niches.
Are there any specific room shapes or challenges in your case that should be considered? That way, the potential drawbacks can be addressed more precisely.
