ᐅ What is the best way to repair Ikea PLATSA furniture yourself?
Created on: 20 Nov 2020 09:13
lamufa
Hello everyone, some time ago I bought an Ikea Platsa shelving unit, and unfortunately, one of the modules has become loose at the joint between the side panel and the bottom panel. I suspect that the Minifix fittings have come undone, but I’m not sure how to best repair this myself without causing further damage to the furniture. Does anyone have experience repairing PLATSA furniture? What tools and replacement parts are ideally needed, and are there any recommended steps to follow? I want to restore stability and avoid drilling additional screw holes if possible. Thanks in advance for your help!
Landontau
21 Nov 2020 08:49
lamufa schrieb:
How exactly does the repair with wooden dowels work? Do I need to drill out the holes completely?
Great question, lamufa! Yes, before inserting the dowels, the old damaged holes should be enlarged to about 8-10 mm (0.3-0.4 inches) deep to ensure a clean fit. It’s important to use a drill bit that matches the size of the wooden dowel precisely – usually 8 mm (0.3 inches) dowels work well for particleboard like Platsa.
lamufa schrieb:
Can I use regular wood glue with wooden dowels, or do I need a special adhesive for particleboard?
You can use regular wood glue. It provides enough strength if you clamp the joints properly and allow the glue to dry fully. Clamping is crucial; otherwise, the hold will remain weak.
In short:
- Drill out the old hole
- Fill the dowel hole with glue
- Insert the dowels and clamp firmly (e.g., with clamps or by screwing the parts together)
- Let it cure for 12-24 hours
Then you can reattach the Minifix fitting. This will improve the stability in the long run.
chenfi
21 Nov 2020 09:33
Additionally: When drilling, be careful not to go too deep, otherwise the anchor may not hold properly. You can also use fine sanding to remove small unevenness before inserting the anchor. This improves the overall grip.
KIN42
21 Nov 2020 11:17
I would like to add that wood press joints in particle boards rely heavily on proper pressing. Even too little pressing pressure results in a weak joint.
For PLATSA furniture, I also recommend reinforcing more heavily loaded joints with brackets if possible. These are small, inexpensive, and can be attached on the outside or inside without being noticeable.
Raymond
21 Nov 2020 12:44
Hello lamufa and everyone participating here! I think it’s really important to approach the repair carefully because PLATSA is convenient, but the thin particle boards are not very forgiving when it comes to mistakes.
In summary, I would recommend:
- Before the repair, carefully check which joint is actually causing the damage.
- For holes that have become worn out, be sure to restore them using wooden dowels and wood glue.
- Tools: drill, dowels, wood glue, screwdriver, and ideally a clamp.
Important: Patience during glue drying is crucial, otherwise the joint will quickly fail again.
If you have any further questions, I’m happy to help!
