ᐅ What is the best way to repair Ikea PLATSA furniture yourself?
Created on: 20 Nov 2020 09:13
lamufa
lamufa
20 Nov 2020 09:13
Hello everyone, some time ago I bought an Ikea Platsa shelving unit, and unfortunately, one of the modules has become loose at the joint between the side panel and the bottom panel. I suspect that the Minifix fittings have come undone, but I’m not sure how to best repair this myself without causing further damage to the furniture. Does anyone have experience repairing PLATSA furniture? What tools and replacement parts are ideally needed, and are there any recommended steps to follow? I want to restore stability and avoid drilling additional screw holes if possible. Thanks in advance for your help!
chenValeri
20 Nov 2020 09:45
With PLATSA, it is most important to first carefully loosen all Minifix connectors and then refasten them. It is best to use a Phillips screwdriver and tighten the Minifix fittings securely. If a part is damaged, you can purchase replacement Minifix inserts individually at a low cost.
Landontau
20 Nov 2020 11:02
Hello lamufa, I have repaired several PLATSA units and would like to share a brief guide with you:
- First, check all Minifix fittings for a secure hold. If any sleeve has loosened, carefully remove it.
- To protect old screw holes, you can fill them with wooden dowels. This improves stability without the need for new drilling.
- Then insert new Minifix fittings and tighten the connections firmly.
- Use a rubber or foam pad under the furniture to prevent pressure marks on the floor.
If you need spare parts, Ikea usually carries compatible replacement Minifix sets. For heavily damaged components, it’s worth ordering replacement units.
TAUPLO
20 Nov 2020 11:26
Oh, PLATSA has its quirks! 😏 I recommend you take everything apart first and clean it thoroughly, as small parts are often loose due to dust.
Then use a set of suitable Minifix fittings; they are essential. And very important: tighten them firmly, otherwise it will remain wobbly! Having a bit of feel for the screw torque doesn’t hurt. 🍀
BAUEVA
20 Nov 2020 13:09
I would like to make a critical comment: Simply tightening Minifix connectors more firmly is not always the solution. If the material around the screws is already worn out, tightening them further often doesn’t help and can even cause more damage.
A more sustainable approach is to repair damaged holes with wood glue and wooden dowels, or even install small solid wood reinforcements before reassembling. This significantly improves stability compared to just retightening or replacing the Minifix, which only holds weakly in worn-out wood.
lamufa
20 Nov 2020 14:22
Thanks for the tips so far! Especially @BAUEVA points out an important issue for me as well: The holes in the particle boards look worn out in some places. So, I’m concerned about just screwing them in tightly.
Now I’m wondering: How exactly does the repair with wooden dowels work? Do I need to drill out the holes completely? And are there specific dowel sizes that work better for PLATSA material?
Also: Can I use regular wood glue with wooden dowels, or is a special adhesive required for particle boards? I would appreciate a guide or a brief explanation.
