ᐅ What is the best way to remove stains from IKEA Metod kitchen cabinet fronts?
Created on: 23 Sep 2021 08:37
drani
Hello everyone, I have kitchen units with IKEA Metod kitchen fronts that unfortunately have some stubborn stains which I cannot simply wipe off. My specific question is: What is the best way to remove stains from IKEA Metod kitchen fronts without damaging the coating or surface? Are there any proven home remedies or special cleaning products that are effective but gentle on the fronts? I have already tried mild all-purpose cleaner, but some stains remain. I look forward to practical tips that are both gentle and effective.
Katan
23 Sep 2021 12:30
Here's a small tip from me: Sometimes, patience is all you need! Gently soaking with lukewarm water and dish soap can work wonders. Then, if you wipe the stain away with a microfiber cloth, you’ll get shiny surfaces without any hassle. No chemicals, just patience – and your kitchen will cooperate! 😉
kemeo68
24 Sep 2021 14:57
islaron schrieb:
Try a vinegar and water mixture (1:1).
Vinegar? I think that is overrated and often risky for these types of surfaces. Acid can damage the fronts and ruin the coating over time. It’s better to work gently with simple methods instead of experimenting with vinegar and acids.
Besides, I wonder why not just use a suitable plastic cleaner. The industrial solution is often underestimated.
Danabla
24 Sep 2021 15:35
kemeo68 schrieb:
I think that is overrated and often even dangerous for such surfaces.
Vinegar can indeed be problematic if used too concentrated or not properly rinsed off. Therefore, it should always be strongly diluted and used only spotwise at most.
The best approach is a combination of:
- Soft cloth
- Mild cleaning agent
- If necessary, some isopropanol for stubborn stains
I am not a fan of most specialty plastic cleaners, as they often contain chemicals that could potentially damage the coating. Caution is advised here.
Kurtis5
24 Sep 2021 16:48
In short: No harsh cleaners, no abrasive sponges—prefer microfiber cloths and mild cleaning agents. For older, stubborn stains, apply a little isopropanol, let it sit, then wipe off.
drani
25 Sep 2021 08:03
Thank you all for the detailed tips! In summary, I will carefully proceed with cleaning in the following order:
- First, clean with warm water and a mild dish soap using a soft cloth,
- Then, if needed, spot-treat stubborn stains with some isopropyl alcohol,
- I will generally avoid vinegar or citric acid, or use them only heavily diluted for lime scale stains,
- And test carefully to protect the surface.
If anyone has further useful advice on gently cleaning matte surfaces specifically, I would still appreciate your input!
