ᐅ What is the best way to remove stains from IKEA Hemnes wood surfaces?
Created on: 1 May 2023 14:17
draga
I have a question about removing stains from wood surfaces, specifically on IKEA Hemnes furniture. These wood surfaces are usually made of solid pine with either a lacquer or oil finish. Unfortunately, I have developed stubborn stains, likely water rings and possibly some grease marks. I definitely want to avoid damaging the surface or compromising the wood protection.
Which methods or products are best suited for removing stains from Hemnes wooden furniture? Are there gentle home remedies that work well, or should I use specialized cleaning products designed for oiled or lacquered wood?
I would also be interested in tips on how to proceed carefully without scratching or discoloring the surface. Thank you in advance for all your advice and experiences!
PLOMA
2 May 2023 10:15
Regarding the question about oil on lacquered surfaces – I agree with you, draga.
meGreg schrieb:
For water stains, you could also try applying a thin layer of olive oil and then gently working it in with a clean cloth.
Olive oil is more suitable for oiled wood surfaces. With clear lacquered furniture, there is a risk that the oil could leave stains or discolor due to insufficient UV resistance.
In your case, I would recommend using mild soapy water and a soft cloth, and for stubborn marks, carefully blend the spot using fine sandpaper (e.g., grit 400). Afterwards, apply a specialized furniture polish or lacquer care product for Hemnes, testing it first in a small, inconspicuous area.
It is important not to soak the surface to avoid wood swelling.
If you’re confident, you can also polish out light water rings using a styrofoam ball and some furniture wax.
Jesus9
2 May 2023 14:09
I can completely understand how frustrating visible stains on Hemnes furniture can be. I had the same problem and spent a long time wondering how to treat the furniture without making it worse.
What helped me was, instead of overworking it, simply touching up a small area with a gentle clear varnish designed for wood. This “sealed” the stain and made it less noticeable. It’s not a full renovation, but rather a small repair.
This gave me the feeling that I was caring for the furniture, not damaging it. Good luck! If you’re still unsure, try it on a small area first.
tra_nina
3 May 2023 08:17
A few practical tips for removing stains from painted Hemnes wood surfaces:
- Hemnes furniture is coated with a water-based clear lacquer that forms a protective layer.
- For cleaning, use a soft, slightly damp cloth with a pH-neutral cleaning agent.
- Avoid alkaline or alcohol-based products, as they can damage the lacquer.
- For water stains, gently dab the affected area with a soft cloth and lukewarm water—never rub.
- For stubborn stains, you can carefully treat the area with a microfiber pad and a mild polish.
- Always dry the surface after each treatment.
If there is lacquer damage, it may be helpful to apply a touch-up clear coat from IKEA or special lacquer care products.
