ᐅ What is the best way to remove scratches from Ikea Pax surfaces?
Created on: 11 Aug 2023 19:37
Darrell
Darrell
11 Aug 2023 19:37
Hello everyone, I recently noticed some light scratches on the surfaces of my Ikea Pax wardrobe, mainly on the matte white doors and the shelves. Since I have been using the wardrobe for some time, I want to avoid damaging the surface or causing unintended discoloration or abrasion marks. Therefore, I am particularly interested in which products and methods work best to remove scratches from the typical Ikea Pax surfaces without damaging the paint or laminate coating. Are there any proven home remedies, special products, or techniques that have worked well in practice? I look forward to any tips, experiences, or warnings about certain methods. Thank you in advance!
KINMIN4
11 Aug 2023 20:03
Simply use a mild soapy solution and a soft cloth for cleaning; sometimes very fine scratches can disappear this way. For slightly deeper scratches, furniture polish or a special scratch remover for paint can help. Important: Always test in an inconspicuous area first.
teyosef
12 Aug 2023 08:21
Hello Darrell,
I understand that the condition of your Ikea Pax surface is important to you. Here is a simple step-by-step guide on how to remove scratches without damaging the surface:
- Cleaning first: Remove dust and dirt with a damp, lint-free cloth and mild soapy water.
- Minor scratches: Start by gently polishing with a microfiber cloth and some furniture polish or car polish designed for delicate surfaces.
- Deeper scratches: In many cases, light sanding with very fine sandpaper (grit 2000 or higher) can help. But only very lightly and carefully—do not press directly on the paint or finish layer.
- Aftercare: Then clean with a damp cloth and treat the surface with furniture wax to restore protection.
It is important not to use harsh cleaning agents, as these can make the surface dull or uneven. If you are unsure, test the method on a hidden corner first.
I have had good results with this approach, and most users report success with this careful method.
I hope this helps!
Jesus9
12 Aug 2023 15:57
I completely understand how annoying those scratches can be, especially when you’ve been using your Ikea Pax wardrobe for a long time and really like it. You don’t want the wardrobe to look worn out after only a short time.
It’s important to take your time and not rush, because sometimes repairs can look worse if the wrong products are used.
I once tried to remove small scratches on a similar wardrobe using polish, but in the end, the surface looked unevenly glossy. My advice is to always test on a small area first and then proceed carefully.
Also, sometimes simple tricks like warming the area and rubbing it with a dry cloth can help soften the plastic slightly and make minor scratches less visible.
Don’t stress out – the goal is to restore the wardrobe’s appearance, and sometimes less is more.
