ᐅ How can I effectively remove old adhesive residue or films from Ikea BESTA units?
Created on: 19 Nov 2017 20:17
Lasujan
I have some old adhesive residues and leftover film on my Ikea Besta furniture that I want to remove without damaging the surface. The adhesive has been there for quite a while, so it is quite stubborn. I would like to know which methods and products are best suited to effectively and gently remove these residues.
I am interested in both simple home remedies and specialized products that work well. It would also be great if you could share tips on the correct procedure—such as the best approach, what to avoid, and whether the furniture surface can be treated afterward to protect it from damage.
If it is relevant: the surfaces are the white high-gloss panels of the BESTA system, which are very delicate. I definitely want to avoid scratches or dulling caused by overly aggressive cleaning.
Thanks in advance for your help!
keelko
21 Nov 2017 08:03
Hey Lasujan,
I was once in the same situation with my Besta – those old glue residues really feel like chewing gum for the soul. Here’s my trick:
- First, soak the surface well with warm water and some dish soap; this often helps to soften the adhesive.
- Then go over it with isopropyl alcohol, and if the residue is still stubborn: apply a little acetone-free nail polish remover on a cotton pad and test very carefully.
I know it sounds harsh at first, but with caution and a soft cloth around the area, it usually works well.
Important: Absolutely no mechanical force – so no knives or aggressive scrapers, otherwise the glossy finish will end up looking like cowhide.
Good luck – fingers crossed the glue will be history soon!
