ᐅ How can I best protect IKEA Metod cabinet surfaces during a move?
Created on: 24 Apr 2023 08:12
nipu9
I am about to move and have a fairly specific question: How can I best protect the surfaces of my Ikea Metod kitchen cabinets during the move? Specifically, I want to avoid scratches, dents, or unsightly wear marks that often occur during disassembly, transport, and reassembly. From your experience, which materials, packaging techniques, or extra precautions are effective in protecting the white matte or lacquered fronts? Are there any special recommendations for handling these sensitive surfaces to prevent long-term damage? Thanks in advance for your advice!
Tofra45
25 Apr 2023 09:43
Just briefly: I protect Ikea Metod cabinets during a move like this:
- All parts clean and dry
- Wrap each large surface with stretch film
- Edges protected with foam or edge guards
- Transport with enough space and padding
This has worked for years without any scratches.
Paxton38
25 Apr 2023 13:12
To add to what has already been mentioned, here is a tip for specially coated surfaces: Avoid using adhesive tapes directly on the fronts. These can damage the finish or leave residue.
Instead, use special furniture stickers or secure the items with stretch wrap and edge protection materials. Long transport distances also require especially thorough protection to prevent mechanical damage.
In summary:
- No sharp edges without protection
- No adhesive tapes on fronts
- Padding between parts
- Careful handling during loading and unloading
This results in significantly better protection for delicate Metod surfaces.
theo63
26 Apr 2023 07:46
Paxton38 schrieb:
To add to what has already been said, I would suggest for specially painted surfaces: avoid adhesive tapes directly on the fronts.
I agree with that but would like to add that stretch film is not completely risk-free for all surfaces. In the presence of moisture or if pressed tightly, matte paints can become discolored or glossy. Long-term storage wrapped in film should be avoided whenever possible.
Fitigu schrieb:
Avoid direct contact between surfaces, for example by using cardboard spacers or protective sheets
I consider this recommendation essential. It makes a big difference whether furniture parts lie directly against each other or are separated by cardboard. This reduces pressure marks and allows better air circulation.
My conclusion: Good protection is always the result of several measures, not just the use of individual aids. Carefully consider which materials are used and avoid creating moisture traps.
nipu9
26 Apr 2023 15:29
KIN42 schrieb:
Additionally, I recommend protecting edges and vulnerable areas with foam edge protectors or specialized edge guard strips.
Thanks for the tip about package edges. Would foam be the best option here, or do you have specific edge protection products from Ikea (or in general) that match Metod cabinets exactly?
theo63 schrieb:
My conclusion: Good protection is always the result of several measures, not just using individual aids.
So would you recommend investing more time in preparation and using the full set of plastic sheeting, edge protectors, cardboard, and moving blankets? Or is that overkill if you handle things carefully?
I ask because I was also thinking of just using thick blankets for all the furniture and no plastic sheeting—would that be advisable for Metod surfaces?
