ᐅ What is the best way to clean IKEA Hemnes furniture when dealing with stubborn stains?
Created on: 4 May 2022 08:37
Andrin57
Andrin57
4 May 2022 08:37
Hello everyone, I recently gave some of my IKEA Hemnes furniture, especially dressers and nightstands, a thorough cleaning. However, I encountered stubborn stains that can’t be easily removed with just a damp cloth and mild dish soap. The furniture is made of solid pine with a white painted finish, and when cleaning, I want to avoid damaging the paint or affecting the wood’s natural character. So, my question to you is: How do you best clean IKEA Hemnes when dealing with really stubborn stains like dried coffee, grease, or ink marks? Are there any special home remedies or cleaning products that are effective without harming the surface? Any experiences with different methods would be very helpful, especially regarding the right cleaners and techniques to ensure neither the wood nor the paint is damaged. Thanks in advance for your tips!
gilen
4 May 2022 09:12
Hello Andrin57, your question is very specific and important because you need to be especially careful with the painted surfaces of Hemnes furniture. I generally recommend the following procedure for stubborn stains:
- First, gently clean with a soft, slightly damp microfiber or cotton cloth and mild dish soap to avoid damaging the surface texture.
- If that’s not enough, you can try a laminate cleaner or a mild all-purpose cleaner, but be sure to test it first on an inconspicuous area.
- For stubborn grease stains, dabbing with isopropyl alcohol (rubbing alcohol) often helps, again applied very carefully.
- For ink stains, I suggest gently rubbing a small amount of toothpaste (not gel) on the spot, then thoroughly wiping it off with a damp cloth.
The basic rule is: do not scrub or use aggressive cleaning agents, as the white paint can otherwise become dull or spotted. At the end, you can polish the surface again with a dry, soft cloth to achieve a nice glossy effect.
Hope this helps!
Sinan-meo
4 May 2022 11:27
That’s a good approach. Additionally, I would suggest testing the compatibility on an inconspicuous spot first, especially since white paint on pine wood can be quite sensitive. For ingrained stains like coffee, it can help to briefly moisten the area with a cotton cloth soaked in warm water, which can loosen the stain without damaging the surface.
Another tip: When using organic solvents, such as isopropyl alcohol, apply sparingly and do not leave it on longer than necessary. Often, gently dabbing is sufficient, rather than rubbing.
For ink stains that have penetrated the finish, I have also had good results with a special eraser, but please use caution to avoid scratching the coating.
It is important to always dry the surface afterward to prevent water marks. For regular maintenance in between, small amounts of wax-based furniture polish work well.
rekijan
5 May 2022 14:53
Andrin57 schrieb:
How do you best clean IKEA Hemnes for really stubborn stains like dried coffee, grease, or ink stains?
I can share my experience – I recently had a small coffee accident on my Hemnes bedside table and was initially unsure what to do. My secret tip: gentle paper recycling! Ok, just kidding. 😊
- I used a damp cloth and then gently rubbed in a little baking soda as a mild abrasive. Be very careful to apply minimal pressure, otherwise you might scratch the surface.
- Afterwards, I wiped everything off with a clean damp cloth and dried it well.
- For the grease stain, I applied a few drops of liquid dish soap directly to the spot, let it sit briefly, and then rinsed it off with warm water – this worked very well.
Patience is key here: clean gently several times rather than scrubbing hard once. And I admit, a bit of luck helps too, but I hope my experience gives you some confidence.
