ᐅ What is the best way to clean IKEA HEMNES furniture after renovation work?
Created on: 10 Oct 2018 18:23
karsonloHello everyone,
I recently completed renovation work in my apartment, and of course my IKEA Hemnes furniture piece (white stained) was affected as well. Now I’m facing the challenge of how to clean it properly without damaging the surface. The main issues are dust, fine sanding dust, and a few paint splatters that I want to remove.
Since Hemnes furniture is usually made of solid pine wood with a lacquer or stain finish, I’m wondering which cleaning methods or products are best, especially to preserve the wood grain and surface condition.
Does anyone have experience with cleaning IKEA Hemnes furniture after renovation dust and paint residues? For example, what kind of cloths (microfiber, cotton?) or solvents are suitable, or whether special wood cleaners should be used?
I would really appreciate practical advice, especially if someone can recommend how to remove stains without sanding, and whether a follow-up treatment with wood oil or a new stain is advisable for Hemnes.
Thanks in advance!
Thanks in advance!
Hello karsonlo, great question!!! 😃 I had the same issue after my last renovation and managed to restore my HEMNES with a few simple tricks!
First, I gently removed the dust using a dry microfiber cloth. Then, I wiped the furniture with lukewarm water and a mild dish soap – be careful not to get it too wet to avoid damaging the wood surface! If water alone didn’t remove paint splatters, I gently dabbed them with a little rubbing alcohol.
Important: Always use a soft cloth and avoid abrasive sponges or scouring agents. After cleaning, make sure everything dries thoroughly.
If you want, you can finish by applying a thin layer of furniture wax; this protects the wood and brings back a nice shine.
Good luck, you’ve got this! 😊
Hello karsonlo,
I’d like to share a simple process I use to clean HEMNES furniture after renovations, to protect the surface and avoid damage.
- Step 1: Dust off dry with a soft microfiber cloth to remove coarse dust and sanding dust.
- Step 2: Clean the surface with a slightly damp cloth and a mild, pH-neutral wood cleaner or alternatively lukewarm water with a few drops of dish soap. Important: Avoid using too much water to prevent swelling of the wood.
- Step 3: Stubborn paint stains can be gently treated with isopropyl alcohol diluted in lukewarm water. Always test first in an inconspicuous area!
- Step 4: After cleaning, thoroughly dry the surface with a dry, soft cloth.
- Step 5: If the surface looks dull or slightly damaged after cleaning, you can apply a clear wood oil or furniture wax. Apply sparingly and allow it to absorb well.
Common mistakes I’ve often seen:
- Using too much water, causing the wood to swell
- Aggressive cleaners or harsh solvents that damage the finish
- Scrubbing too hard with abrasive sponges
With this method, you should be able to clean your HEMNES gently and effectively.
I hope this helps!
I hope this helps!
noge58 schrieb:
If water alone isn’t enough to remove paint splatters, I’ve gently dabbed them with some denatured alcohol.I would advise caution here. Depending on the wood surface and the type of finish, denatured alcohol can cause more damage than benefit.
LAURE-TA schrieb:
Stubborn paint stains can be carefully treated with isopropyl alcohol diluted in lukewarm water. Always test on an inconspicuous area first!This is a better approach since isopropyl alcohol is generally milder than denatured alcohol. However, I wonder if chemical solvents are necessary at all when renovation residues usually consist only of fresh paint or dust.
Wouldn’t it make more sense to start mechanically with soft cloths or special erasers (such as leather erasers) before turning to solvents? Especially on a HEMNES finish, which is either lacquered or stained, aggressive substances can roughen the surface or cause it to appear dull.
What do you think about a three-step process:
- Dry cleaning
- Damp wiping with a mild cleaner
- Mechanical removal (eraser, etc.)
And only if that’s not sufficient, use solvents very carefully and locally? This way, the surface is protected and risks are minimized.
