ᐅ What is the best way to attach the back panels on Ikea Platsa units?
Created on: 20 Apr 2020 19:23
gaioleo
gaioleo
20 Apr 2020 19:23
I am currently assembling a larger Ikea Platsa system and have a question about the best way to secure the back panels of the individual units. The instructions are somewhat basic, and I want to make sure the back panels are firmly in place and won’t sag or come loose over time.
Specifically, I am wondering about the method of attachment: Should the thin particleboard back panels simply be slid into the provided grooves, or is it better to additionally secure them with nails or screws? If so, what should I watch out for to avoid damaging the material?
Also, are there any special tips to ensure the back panels are installed with maximum stability and durability? I’m thinking especially about handling the thin and somewhat delicate back panels, which also serve to prevent twisting.
I would appreciate any concrete advice or personal experience!
sonpar
20 Apr 2020 20:18
The back panels for Platsa are designed to slide into the groove strips. Nails are common and can be gently tapped in with a small hammer. I would rather avoid screws, as the thin panel can split. It is important to keep the back panel straight and free of warping before attaching it.
liste
21 Apr 2020 07:52
Whether to use only tongue strips or to add nails should mainly depend on the planned load and the expected usage duration.
sonpar schrieb:
I would rather avoid screws; the thin panel can split.
I basically agree with that, but the stability of the back panel is crucial for the entire piece of furniture. I would recommend that if you use nails, they should be driven in very flat and sparingly to avoid splitting.
There is also the option of using special back panel nails that cause less damage to the material. Some people use small screws with washers to better distribute the load, but that requires precise pre-drilling. Another question is how important the twist resistance provided by the back panel is in your system – Ikea’s description is quite brief on this.
Declan55
22 Apr 2020 11:11
I find the back panels of Platsa really easy to install – just slot them in, and for me, they hold well without needing many nails! 😊
If you’re worried about stability, you can add a few nails on the sides for extra support, which really helps! It’s best to use a small hammer carefully to avoid splitting the back panel.
Try it that way first; I was surprised at how stable the system is! Good luck, and don’t get discouraged – it will turn out great!
