ᐅ How can I enhance Ikea Platsa furniture with homemade handles?
Created on: 29 Jan 2021 18:04
Moses36
Moses36
29 Jan 2021 18:04
Hello everyone, I am planning to upgrade my Ikea Platsa furniture with custom-made handles, as I find the original handles too plain and lacking individuality.
So my question is: Which materials and techniques are best suited for making your own handles that are both durable and visually compatible with the simple design of Platsa? So far, I have considered wood, leather, or metal, but I am unsure which option is the most practical in terms of durability, easy installation, and care requirements.
I am also interested in the best way to attach the handles, as I would like to avoid damaging the drill holes or leaving noticeable marks if I need to replace them later. It would be great if you could share your experiences with DIY handles on Platsa furniture or recommend suitable tools and steps for the process.
Thanks in advance for your advice!
PECLARISSA
29 Jan 2021 21:17
Moses36 schrieb:
Which materials and techniques are especially suitable for making your own handles that are both durable and visually match the simple design of Platsa?
I would definitely go with wood – it might sound old-fashioned at first, but with a bit of sanding and a nice finish, it looks really elegant. I once made handles from cherry wood, which has a warm tone and is easy to shape.
For mounting, I recommend using brass or nickel-plated screws that you can fasten from the back with a screwdriver. This protects the surface and looks clean. If you like leather, you can also use leather straps—just adjust the holes and stretch the straps tight. This creates a nice, soft contrast to the smooth fronts.
One more tip: be sure to measure carefully beforehand to place the drill holes correctly. There’s nothing worse than inaccurately drilled holes that are visible later on! Have fun crafting 😉
GUSTAVO56
30 Jan 2021 08:46
PECLARISSA schrieb:
I would definitely recommend wood – it might sound old-fashioned at first, but with some sanding and a nice finish it looks really elegant.
I fully agree with this and would like to add some details: For custom-made handles on Ikea Platsa units, solid wood is indeed one of the most durable and adaptable materials. The key is choosing the right type of wood – hardwoods like beech, oak, or maple offer great stability and are less prone to dents or breaks.
Regarding the manufacturing process: first sand a suitable piece of wood with a grit of about 80, then cut it to the desired shape, followed by finer sanding (120–150 grit). After that, seal the wood with a high-quality clear varnish or oil to protect against moisture and wear.
Attachment to Platsa is usually done through the existing holes, but it’s advisable to precisely mark these holes on the handle with a small drill guide or template before drilling to avoid misalignment. Screws should ideally be made of stainless steel to prevent rust staining on the furniture.
One special aspect: Platsa doors are thin, so without additional reinforcement the screws may not hold well. I have often used small wooden washers or wood blocks as backing to secure the screws and improve the handle’s stability.
If you are considering leather handles, be sure to use thick, firm leather and reinforce the attachment points with metal eyelets to prevent tearing.
I would be interested to know which furniture pieces you plan to modify and what type of use you envision, as this will influence the choice of material and mounting method.
Dirkmin
31 Jan 2021 12:39
Moses36 schrieb:
I’m also interested in the best way to secure the handles because I want to avoid damaging the drill holes or leaving large marks if the handles need to be replaced later.
Regarding attaching homemade handles to Ikea Platsa furniture, I recommend the following approach:
- Use the existing handle holes to avoid making additional holes in the furniture.
- If adjustments are necessary, work with very precise measurements and drill pilot holes with a thin drill bit to prevent damaging the material.
- Screw the homemade handles in with short but sturdy screws inserted from the back. Make sure the screw length matches the thickness of the furniture.
- Avoid using glue or nails, as these can damage the front of the furniture or make repairs more difficult later.
Additionally, vinyl or felt pads on the inside of the doors can help minimize pressure marks caused by the screws.
In summary: Working carefully protects the furniture from unwanted damage, and using the existing holes makes later changes or removals easier. This way, the appearance remains intact in the long term.
