ᐅ How can I prevent stress cracks in the panels when assembling IKEA Besta units?
Created on: 9 Feb 2015 18:37
NENEPA
NENEPA
9 Feb 2015 18:37
I am currently assembling an IKEA Besta shelf and have been increasingly experiencing stress cracks in the panels – especially along the edges and areas where screws are placed. These cracks seem to result from uneven stresses in the engineered wood, probably caused by incorrect screw installation or insufficient preparation.
Does anyone have tips or proven methods to prevent stress cracks when assembling Besta panels? I am particularly interested in:
- Proper screwing technique (torque, screw positioning)
- Panel preparation (pre-drilling, allowance for expansion)
- Handling moisture or storage before assembly
I understand that particleboard or MDF is more prone to cracking than solid wood, so I would appreciate specific advice on how to minimize such stresses during furniture assembly.
Thanks in advance for any help!
sarGabriel
9 Feb 2015 19:03
Hello NENEPA,
stress cracks usually occur when screws are inserted too deep or too close to the edge. I recommend:
- Do not place screws directly at the edge, keep a minimum distance of 2-3 cm (about 1 inch)
- If possible, pre-drill (even though IKEA boards do not always require it)
- Insert screws slowly and evenly, do not overtighten
This way, you can significantly reduce the tension in the board.
deoke
10 Feb 2015 08:29
I would like to go into more detail on this topic, as stress cracks in wood-based panels like particleboard or MDF often have several causes:
- Material properties: These boards react to moisture and temperature, meaning they expand or contract. If screws are placed too close to the edge or without enough clearance, stresses will develop.
- Screw installation: I recommend always pre-drilling holes, especially near edges. The drill hole should be slightly larger than the screw shaft to protect the panel from splitting. It is also advisable not to fully tighten the screws but only enough for them to hold without pressing too hard.
- Edge protection: Edges are particularly vulnerable. After drilling, you can lightly chamfer them to prevent the material from tearing out directly around the hole.
- Moisture control: Store the panels in a dry, well-ventilated area before assembly. Fluctuations in moisture can cause swelling, making installation more difficult and cracks more likely.
From my experience: If you pre-drill, avoid placing screws right at the edge, and do not overtighten the screws, you will very likely prevent stress cracks. By the way, I would be interested to know exactly how you set the screws on your Besta? Hard edges or softer wood areas might also be a factor.
LEAH_TAN
10 Feb 2015 10:54
Hello NENEPA and all other wood and furniture enthusiasts!
I just want to encourage you – stress cracks can be annoying, but the right approach really helps! I always use pre-drilled holes and avoid placing screws too close to the edge, and then I don’t have any issues!
One more tip: leave the panels in the room where they will be installed for a few hours before assembly. This gives the panels time to adjust to the humidity in the air 💪🏻
Good luck with the assembly, you can do it!
rotofra
11 Feb 2015 07:12
sarGabriel schrieb:
- Do not place screws directly at the edge; leave a minimum distance of 2-3 cm (1-1.2 inches)
From a technical perspective, this is very important. I would like to add how I systematically proceed during assembly to avoid stress cracks in IKEA Besta units. For those who prefer step-by-step instructions, here is my method:
1. Store panels at room temperature with appropriate humidity before assembly (ideally 18-22°C (64-72°F), 40-60% relative humidity).
2. Check screw positions and, if possible, pre-drill holes – the drill bit should be about 0.5 mm (0.02 inches) larger than the screw shank.
3. Slightly chamfer the drill holes at the edges to prevent tear-out.
4. Insert screws slowly and tighten gently on the final turn – over-tightening is counterproductive.
5. If possible, leave small expansion gaps at points prone to stress or allow sufficient clearance during mounting.
I combine these measures to significantly increase the furniture’s lifespan and minimize stress cracks. It might seem a bit much, but often it’s the small details that make a difference.
Henry
11 Feb 2015 21:47
deoke schrieb:
By the way, I’m curious about how you exactly place the screws on your Besta? Hard edges or softwood areas might also be relevant.
I think that’s a very good point. I also had problems with cracks in my Besta and found that I had placed the screws too close to the edges of the back panels. That seems to cause stress buildup.
Sometimes it also makes sense to take your time and pause briefly while screwing in, especially when you notice the material is “moving.” For me, it’s a learning process, and there’s no reason to get discouraged because of that.
Anyone who regularly assembles furniture knows these pitfalls, but together we can surely find solutions!
