Hello everyone, I am looking for tips on how to effectively prevent paint damage on Malm furniture. I understand that these pieces are especially sensitive to scratches, chipping, or discoloration due to their MDF construction and painted surface. What are your proven methods for keeping the surfaces looking flawless for as long as possible? Do you use any special care products or protective films? Which everyday precautions do you consider most important to avoid unpleasant damage? I look forward to detailed answers and experiences.
Hey Mauko44, great question! Malm furniture is really nice, but you quickly notice that the surface isn’t the most durable. My tip: use soft felt pads under all items – and make them large enough to cover a good area. This way, you can avoid most scratches. Also, use light cloths when moving furniture around. Oh, and don’t use harsh cleaning agents! Lukewarm water with a little dish soap usually does the trick. 🙂 A small household myth is that you absolutely need special furniture polishes – these can actually cause more harm than good.
SauDietmar8 Dec 2022 15:07Mauko44, I’m happy to add a brief tutorial depending on the situation:
1. Regular cleaning: Wipe off dust with a microfiber cloth, avoid abrasive cleaners, and use a mild soap solution.
2. Protection from heat and moisture: Do not place hot objects directly on surfaces; use coasters or trays.
3. Handling scratches: Small scratches can be repaired with wax or touch-up sticks available from specialist suppliers.
4. Protective films: Apply transparent, thin adhesive films to areas subject to heavy use.
A common mistake is placing cups directly on the surface without coasters – this quickly leaves unsightly rings and damages the finish. In summary: prevention is better than repair!
FeAndreas18 Dec 2022 16:44Hello Mauko44, since you are interested in a detailed answer, here are some technical details about the coating and sensitivities to help avoid damage.
Malm furniture is often coated with a multi-layered powder coating or UV-cured lacquer. These types of finishes are smooth and visually appealing but mechanically sensitive. Micro-scratches occur quickly, especially from dust that is dragged across the surface by everyday handling of objects.
That’s why it is important not only to wipe the furniture smoothly but to first remove coarse dust. The choice of cloth is also crucial: microfiber cloths with a soft texture and no dirt particles are a must.
Another factor is temperature and humidity differences—direct sunlight can make the coating brittle and prone to cracking. Therefore, I would recommend not placing Malm furniture permanently near windows, or at least using an opaque curtain for protection.
Additionally, be careful when placing items near edges and corners: the coating is often thinner there, making these spots more vulnerable to chipping from impacts or edge pressure.
Have you noticed whether your furniture is exposed to specific stresses? That information would help to tailor the advice even more precisely.
FeAndreas1 schrieb:
Malm furniture is often coated with a multilayer powder or UV-cured lacquer.Interesting, I didn’t know that! It explains why I’ve already noticed small surface cracks at home when exposed to direct sunlight. 🙂 In that case, shade really helps more than care products. Thanks for this technical clarification!
SauDietmar9 Dec 2022 10:15Mauko44 schrieb:
What are your proven methods for keeping surfaces looking flawless for as long as possible?Regularly inspecting the furniture surface is important for this. Damage becomes noticeable sooner, allowing you to intervene early, for example by promptly repairing the finish. For larger pieces of furniture, it also helps to rotate the areas in use so that certain spots aren’t subjected to the same stress all the time.
A small addition: try to avoid using permanent pens or markers near the furniture. It’s better to use a few with easily removable ink. Better safe than sorry.
