ᐅ How can I prevent damage when transporting Malm furniture?
Created on: 7 Aug 2023 08:03
do-bar
Hello everyone, I would like to start a practical discussion: How can I prevent damage when transporting furniture from IKEA’s Malm range?
Specifically, I am interested in the best ways to protect the relatively sensitive surfaces and edges when the furniture is transported in moving boxes or by other means.
It would also be helpful to learn how to store disassembled Malm furniture properly to avoid unexpected problems from damaged parts during reassembly.
I look forward to precise tips and experiences, including recommendations for special packing materials or techniques.
gasidney
7 Aug 2023 10:37
TEOZAR schrieb:
Take photos of the screws before disassembling or note where each one goes
This is generally always a good tip. I use small bags for this and label them with the component, which works well.
Davidleo
7 Aug 2023 10:59
Great tips so far! I can also recommend buying protective films designed for delicate surfaces directly from a furniture store. These are specially made for sensitive finishes and often adhere better than regular bubble wrap.
And everyone, don’t rush! Careful handling during transport pays off, otherwise the new wardrobe won’t be enjoyable anymore. 🙂
narDietmar
7 Aug 2023 11:13
Summary of Key Points:
- Empty furniture before transport
- Carefully pad all parts
- Protect edges with adhesive guards
- Keep screws and small parts sorted and labeled
- Secure furniture properly and avoid stacking
- Store in a dry and level area
This systematic approach significantly reduces transport damage.
do-bar
8 Aug 2023 07:44
Thank you very much for the detailed and well-considered responses! I hadn’t previously thought about the advice regarding storage and the use of edge protectors.
Could you also briefly mention if there are specific parts of Malm furniture to watch out for during reassembly that are often damaged or misaligned? What is the best way to proceed to avoid problems later on?
TEOZAR
8 Aug 2023 08:12
When rebuilding Malm furniture, special attention should be given to the drawer slides.
If these are not aligned properly, drawers may not close correctly or may stick. A temporary test of all drawers before final screwing is helpful.
Additionally, the corner connector plates of the carcass are often critical; if they are too loose, the frame can become unstable.
My tip: Create a calm environment during the initial assembly and follow the instruction manual carefully. Document any minor adjustments beforehand in case further fine-tuning is needed.
andre3
8 Aug 2023 08:37
TEOZAR schrieb:
The drawer slides deserve careful attention.
These are often the cause of problems after transport. Also, be careful not to overtighten the screws to avoid damaging the material.
I recommend initially tightening the screws only lightly at each critical joint, then checking all connections for proper fit, and only once everything fits correctly should you fully tighten them.
