ᐅ How can I prevent damage when assembling the IKEA Brimnes furniture?
Created on: 16 Oct 2022 08:37
jenssinHello everyone, I am planning to assemble the IKEA Brimnes wardrobe and have some concerns about how to avoid damage to the components. Specifically, I am interested in precautions to take when handling the very thin particle boards and when inserting dowels and screws. It would also be helpful if someone could share tips on how to properly follow the instructions and use the tools to prevent twisting or incorrect assembly. Are there common points where the Brimnes tends to get damaged, and what is the best way to address these? I look forward to your expert advice and experiences!
Check all parts for damage before assembly. Handle particle boards carefully; do not bend or force them. Always position dowels precisely and avoid overtightening; screw in screws gently. Follow the instructions carefully and do not skip any steps. This helps prevent most damage.
I recommend the following procedure to avoid damage when assembling Brimnes furniture:
- Preparation phase: Carefully unpack all components and inspect them for defects, cracks, or scratches.
- Workspace: Set up a flat and sufficiently large work area with a soft protective surface, such as a blanket or cardboard, to protect edges and surfaces.
- Inserting screws and dowels: Never force dowels in with brute force; instead, use gentle hammer taps or hand pressure when possible. Pre-drilling screws is generally not necessary for IKEA furniture, but never tighten screws with excessive force.
- Assembly: Align side panels and back panels precisely, avoiding any warping of parts—tension often leads to damage or warped boards.
Common trouble spots are the edges of doors and the drilled holes for connector fittings. Careful alignment and gentle handling are very helpful here.
Summary: Patience is key.
Genevieve17 Oct 2022 07:09BELLA34 schrieb:
Gently screw in the screws.That is a good principle, but how exactly do you define "gently" in this context? Torque control is hardly precise with basic cordless screwdrivers. In my experience, the risk of damaged panels often results not only from applying incorrect force but also from using the wrong tools.
Furthermore, why does IKEA use such thin panels that are so delicate? Wouldn’t it be more sensible to demand higher-quality, more durable options or at least clearer, more cautious assembly instructions right from the start? This brings me to the question of whether you have ever tried alternative assembly methods that go beyond the usual IKEA standard. I think a discussion about this would be very interesting.
Genevieve schrieb:
That is a good principle, but how do you actually define "gentle" in this context?As a reply, one can say: "Gentle" here means tightening the screws with just enough torque to make the joint secure and stable without overstressing the material.
- Brimnes consists of thin particleboard panels with a veneer foil that can swell quickly or crack if overtightened.
- Therefore, a cordless drill should be used at low speed and low torque setting, or preferably a manual Phillips screwdriver.
Nofege schrieb:
Tensions often cause damage or warped panels.This is exactly one of the main reasons for damage with Brimnes. The parts need to be aligned flush during assembly. Especially with the back panels, pay attention to even seating and initially fix them with only a few screws until everything fits correctly.
In summary: focusing on the right tools, controlled work, and patience are essential.
