ᐅ How can I prevent damage to IKEA BRIMNES furniture during transport?
Created on: 1 May 2017 09:13
nibevin
nibevin
1 May 2017 09:13
Hello dear community,
I am planning a move soon and need to transport my IKEA Brimnes furniture. Since these pieces are made from relatively thin wood panels and there have been damages to similar furniture during transport in the past, I want to do everything right this time from the start to avoid scratches, dents, and damage to edges and surfaces.
Therefore, my question is: What practical and proven methods do you use to prevent damage to IKEA Brimnes furniture during transport? I would like to know how to pack before transport, what to pay attention to regarding load securing, and what to consider when loading and unloading to prevent such damage.
Perhaps you also have practical tips for the best loading order or which materials work best for this?
I look forward to your experiences and advice!
Edric
1 May 2017 11:47
Hello nibevin,
I completely understand how frustrating it is to discover small but visible damage on your furniture after all the effort of moving. I’ve experienced that frustration myself.
What helped me was fully disassembling the furniture before transport and carefully wrapping each part with blankets or bubble wrap. The edges of the BRIMNES pieces, in particular, are quite delicate – so protecting them is especially worthwhile.
I also recommend not just throwing the parts randomly into the van, but stacking them flat and neatly. I used layers of cardboard or foam between items to prevent friction.
One important tip: When loading, make sure heavy and sturdy items are placed on the bottom and lighter pieces on top. This helps avoid pressure marks or breaks from weight pressing down.
I’m looking forward to more tips, especially regarding securing the load inside the vehicle to prevent shifting during transit.
deoke
2 May 2017 08:02
Hello nibevin,
I would like to address your question in more detail, as transporting IKEA BRIMNES furniture presents significant challenges if you want to avoid damage.
First, preparation: It is essential to completely disassemble the furniture. BRIMNES often involves screws and dowels that should be carefully removed and stored in an organized way – ideally in a clearly labeled box.
For packing, I recommend multiple layers of protective material: first, place a thin layer of foam padding or blankets directly on the surfaces, then cover the edges with edge protectors made of foam, cardboard, or padded foam corners. The edges are often the “weak points” where damage occurs.
Regarding positioning in the vehicle: flat and level is the best way to store them. It is advisable to stabilize the disassembled panels with flat wooden slats or cardboard tubes as spacers. This prevents point loads that could cause dents.
A common mistake is insufficient load securing: I strongly recommend using ratchet straps to secure the individual furniture packages so they cannot move during transit. Sudden braking or cornering can easily cause damage.
As a final tip, consider the loading order: load heavier and sturdier items first, then the more delicate furniture parts, which ideally should not be in direct contact with the vehicle walls.
Also, ask yourself which transport method you plan to use, as small vans and car trailers each come with specific challenges. More information on this would help me tailor my advice even more precisely.
luAlbert1
3 May 2017 19:36
deoke schrieb:
For packaging, I recommend several layers of protective material: first place a thin layer of foam cushioning wrap or blankets directly on the surface, then cover the edges with edge protectors made of foam, cardboard, or padded foam corners.
I think this is a typical case of overkill. Of course, protection is important, but you should also allow for the fact that the furniture is made to be transported. IKEA furniture isn’t fragile antiques.
In my opinion, the trend here is to be overly cautious, which can actually be costly and too complicated. Instead, I would recommend simply being careful during transport and avoiding packing too tightly so nothing gets crushed.
Also: small damages on BRIMNES items often show traces of assembled panels that become more vulnerable to moisture during transport. There’s no need to panic unnecessarily and wrap the furniture beyond recognition if it’s handled properly.
Don’t get me wrong, I respect proper handling, but I think with IKEA furniture, you shouldn’t turn every little thing into a drama.
