Hello everyone, I recently purchased a MALM bed from IKEA and am in the process of securing it to the wall. My specific question is: How can I safely and securely mount the MALM bed frame to the wall without damaging the frame or the bed’s surface? I want to avoid cracks, chips, or visible damage to the wood or finish caused by screws or other fasteners. Are there any special techniques, tools, or fasteners that are particularly suitable for this? It is important to note that I do not want to drill holes into the wall, as this is a rental apartment, but I still want a secure attachment. I look forward to your detailed tips and advice!
Hello, this is a very good and important question!
Basically, with IKEA furniture like the MALM bed, it is important to handle the surfaces carefully because the laminate or lacquer coatings are delicate. To secure the bed safely and stably without damaging the frame, I recommend the following approach:
1. Use wall brackets with padding or protective pads that protect the contact surfaces. For example, small felt or rubber pads between the bracket and the frame.
2. Instead of screwing directly into the frame, you can fix the bracket to the wall and secure the bed with tension devices or special furniture clamps.
3. If drilling into the wall is not possible, clamp or tension systems that work between floor and ceiling are suitable, as they do not damage the furniture.
4. Also, make sure all fastening materials are rust-resistant and sturdy to keep the structure safe.
I hope this helps you for now. If you provide exact dimensions or wall materials, I can give you more specific advice!
chenValeri3 Apr 2021 20:18If you want to avoid damaging the MALM frame, it’s best to use clamp holders or furniture brackets with rubber pads. Screw them into the wall and secure them with a protective layer between the frame and the bracket. Avoid drilling holes into the wood.
Nadine schrieb:
Use wall brackets with padding or protective covers to protect contact surfaces. That’s a good tip and shouldn’t be underestimated.
To explain this in more detail: The MALM bed is made of veneered particleboard, which is sensitive to point loads. Especially directly screwing into it can quickly cause the surface to chip or the laminate layer to separate. Therefore, I recommend never screwing directly into the bed frame but always using a connection with a contact surface that distributes pressure.
A particularly gentle option is using so-called furniture clamps or tensioners that do not require drilling. These are inserted between the wall and the bed and apply gentle pressure to stabilize the furniture.
If you are willing to drill into the wall, I suggest using anchors with a soft coating and padding the contact points on the frame with soft foam or felt. This helps prevent the frame from being damaged when it moves.
Important: Carefully check the wall condition and the weight of the bed beforehand to ensure the fastening will hold. Of course, I understand the situation regarding rental apartments.
One more question: Would you prefer a completely hole-free solution, or are small drill holes in the wall acceptable? Also, what type of flooring do you have (wood flooring, carpet, tiles)?
kibutar schrieb:
Would you prefer a completely hole-free solution, or are small drill holes in the wall acceptable? Hello, thank you for your detailed response! Actually, I would prefer to avoid drill holes in the wall because I live in a rental apartment and don’t want to leave any marks later on.
My floor is laminate, so solutions without drilling and completely damage-free are preferable. Still, I want the bed to be stable and not wobble, especially since I tend to move around a lot at night and otherwise the frame shifts frequently.
Are there special tension systems or brackets that can be easily adjusted to ensure stability? What would you recommend if wall mounting is out of the question but damage to the frame should also be avoided?
loisbi schrieb:
Are there perhaps special tension systems or brackets that can be adjusted fairly easily to ensure stability?Yes, such systems do exist. For example, so-called "telescopic bed frame stabilizers" or "tension poles." These are clamped between the ceiling and the floor and secure the bed additionally to the wall or a stable position without screws.
Some products have rubber buffers that do not damage your MALM or the wall. These tension and compression systems are usually height-adjustable, allowing precise fitting. This is especially popular in rental apartments, as no drilling is required.
Also, look into furniture clamp holders available at hardware stores or online, often combined with felt-like protective pads to prevent pressure marks.
If the bed still slips, you could additionally place furniture glides with non-slip rubber pads under the legs.
