ᐅ How do I attach Malm furniture to drywall?
Created on: 2 Apr 2024 08:23
anluis
I have several Malm dressers from Ikea that I would like to attach to drywall panels, as I live in a rental apartment and stability and safety are important.
My specific questions are: Which anchors or fastening methods are best suited for drywall to securely fix the furniture? Should I drill directly into the metal studs behind the drywall? Or are special hollow wall anchors sufficient? Are there any particular precautions to take to avoid damaging the wall while still ensuring a secure attachment?
I would appreciate a detailed explanation, possibly with recommendations for suitable anchors or techniques. Thanks in advance!
kaubi
3 Apr 2024 09:02
Regarding your safety concerns with children and mounting on drywall, anluis, here is my fully technical suggestion:
Before drilling:
- Scan the wall carefully with a multi-detector, preferably one with a deep scan function, to locate studs and electrical wiring.
Installation:
- Choose multiple mounting points, at least 3 screws per dresser, with two of them, if possible, directly into the studs.
- Use metal toggle anchors (expansion anchors are not recommended for full weight).
- For drilling into the stud, use special metal drill bits and control the screw torque with a torque wrench—tighten securely but not overly tight.
Alternative:
- Additionally, you can secure sturdy metal brackets at the floor and back wall to further reduce the risk of tipping.
Wall thickness:
- Keep in mind that drywall panels are usually 12.5 mm (1/2 inch) thick, so the anchors must engage well in the cavity; otherwise, the fixings will not hold long.
If you follow these steps for mounting, the furniture should stand safely even with toddlers.
LOGEMIN
3 Apr 2024 10:30
kaubi schrieb:
You can also attach sturdy metal brackets to the floor and the back wall to further reduce the risk of tipping.
Very good tip. Additionally, if anyone wants to make it even safer: there are special wall and furniture restraints (e.g., cable tie-like straps with screws) that are quite easy to install and greatly prevent tipping.
These are especially useful in rental apartments where maximum stability with minimal wall damage is desired.
theo63
3 Apr 2024 11:18
One last thought: The entire fastening system only provides safety if it is installed correctly. An inexpensive wall plug from a hardware store can fail when it matters most.
In my opinion, it is best to rely on certified products and, if necessary, consult professionals briefly—especially if there are children in the household.
I hope you, anluis, find these tips helpful and manage to find a safe solution.
