ᐅ How do I secure IKEA PLATSA units to laminate flooring?
Created on: 10 Jan 2020 08:42
Naumiguel
Naumiguel
10 Jan 2020 08:42
Hello everyone, I recently bought an IKEA Platsa shelving unit and want to secure it to my laminate flooring. I'm wondering about the best way to fasten it so the unit stands securely without damaging the floor. My main concern is that direct mounting on the laminate could cause pressure marks or scratches. Are there specific installation methods, tips, or materials that work well for attaching Platsa units to laminate flooring? I am also interested in whether the unit should be additionally fixed to the wall and how to do this if the laminate floor underneath is very delicate. I look forward to your advice and experiences.
BELLA34
10 Jan 2020 09:03
I would definitely place a non-slip mat underneath to prevent the shelf from sitting directly on the laminate flooring. Then, secure the shelf to the wall to ensure stability. This also protects the floor from damage.
Palenar
10 Jan 2020 10:28
First, it is important to know exactly which version of the PLATSA you have, as the mounting options can vary slightly depending on the model. You certainly want to achieve stable support on one hand, but at the same time avoid damaging the laminate flooring. I recommend the following approach:
- Place thin felt pads or special rubber mats under the shelf to distribute the pressure on the surface and prevent scratches.
- Secure the shelf not only on the floor but also definitely to the wall. Angle brackets or supplied anchors are suitable for this, depending on your wall type.
- If you do not want to make holes in the laminate (which is generally not recommended), avoid screws or plugs in the floor area.
Also consider how much weight the shelf should carry and how intensive the use in the room will be. If you tell me more about the weight and the intended location, I can give you more precise advice.
Naumiguel
10 Jan 2020 11:02
Thank you for the detailed response! I plan to use the shelf in my living room, mainly for books and some decorative items, so the load will be moderately heavy overall. The wall is standard plaster on concrete, so using anchors should be feasible. I am aware that the laminate flooring can develop sensitive spots. Would it make sense to use a thin wood panel or MDF board as an additional base under the felt pads? I’m concerned that even with sliders, pressure marks might eventually appear under heavier weight.
toril
10 Jan 2020 13:49
A thin wood or MDF board as an underlay is definitely a very good idea when it comes to preventing pressure marks on sensitive laminate flooring. Keep in mind:
- The board should be at least 8 mm (0.3 inches) thick to distribute the load effectively.
- It must be cut precisely to avoid creating trip hazards.
- Also, clean the laminate floor thoroughly before placing the board to avoid sand grains that can cause scratches.
- Attach felt pads to the feet of the shelf, even on top of the board.
For wall mounting, I recommend using appropriate anchors for concrete walls (e.g., expansion anchors) and avoiding cavity wall anchors.
This way, you achieve maximum stability while protecting the floor underneath.
Jamalli
11 Jan 2020 07:26
Interesting tip, but I wonder if this might increase the shelf height, potentially causing it not to align flush with adjacent furniture anymore. Also, it would be worth checking whether the uneven transition (laminate – wooden board – shelf) could affect the stability or cause the shelf to tip.
Furthermore, I am concerned whether using such an underlay might lead to moisture accumulating between the laminate and the board, which could have long-term effects on the flooring.
Has anyone had experience with this type of intermediate layer and its long-term impact? Or alternative solutions that address these specific concerns?
