Hello everyone, I am currently planning to install an IKEA Platsa system in my office, but directly on a glass wall. I understand that IKEA usually does not provide specific mounting systems for glass walls with the Platsa range. The issue is that the glass wall does not allow for traditional anchor holes, and I definitely don’t want to compromise the stability of the wall.
So my question is: What is the best way to securely and permanently attach IKEA Platsa to glass walls without causing damage or instability? What fastening options or adapters have you seen in use or tested yourselves? Are there perhaps alternatives like special clamping mechanisms or adhesive techniques that work reliably?
I look forward to tips, experiences, and advice, especially if anyone has attached IKEA furniture directly to glass before, preferably with details about the process and material selection.
Hello Martar,
to address your question in an organized way, it is important first to clarify the exact type of your glass wall: Is it laminated safety glass (LSG), tempered safety glass (TSG), or another type of glass? The attachment methods vary significantly since TSG generally should not be drilled, whereas LSG allows for some drilling if done professionally.
Experts generally advise against mechanical fastenings that directly penetrate the glass wall without ensuring adequate load-bearing capacity. There are two main approaches to consider:
- Clamp fittings: These grip the glass panel without damaging it. It is important that the clamps have soft, scratch-resistant seals to protect the surface and distribute the load evenly. This requires that there is no other glass panel or structure directly behind the glass wall.
- Adhesive techniques using specialized adhesives: UV-cured adhesives designed specifically for glass and metal are suitable for this method. It requires an absolutely clean surface and precise curing to ensure a permanently load-bearing bond. A disadvantage is the limited load capacity without additional reinforcements.
Regarding IKEA Platsa, the system is generally designed to be screwed into solid walls. A possible workaround would be to use a thin but sturdy intermediate structure (e.g., a wood or metal panel) that is attached to the glass wall by clamping or a specialized glass fitting, and then the Platsa units can be screwed onto this. This increases safety and avoids direct intervention in the glass.
Does your glass wall have a profile construction or frame to which you could attach screws? How heavy are the furniture units you want to install? The more information you provide, the more specific the recommendation can be.
GUMARTINA27 Sep 2021 08:37lorena schrieb:
Clamp brackets: These grip around the glass panel without damaging it.This is the most important point: always use clamp brackets and do not drill into the glass unless it is specially load-bearing glass.
Alternatively, you can try heavy-duty adhesive strips or mounting glue designed specifically for glass, but only for lightweight furniture parts. Otherwise, it is better to use an intermediate panel.
RonJarrett28 Sep 2021 13:52In addition to the previous explanations, I would like to point out the following aspects:
- Structural support: Glass walls are not load-bearing walls in the traditional sense. Loads from furniture such as Platsa units must be carefully planned to avoid risks.
- Mounting options: Mechanical fastening (drilling, anchors) is usually only permitted with thick laminated safety glass (VSG) with tested drill holes. This is prohibited with tempered safety glass (ESG). Clamping profiles or special glass composite carriers for mounting on glass should be preferred.
- Regarding the IKEA Platsa system: Since it is modular and primarily fastened to the wall with screws, it is advisable, as mentioned earlier, to install a supporting structure made of wood or metal panels in front of the glass wall.
- Safety: Seek professional advice from a glass specialist company. Often, the requirements for fastening and load capacity are binding, especially for glass room partitions.
Conclusion: Direct fastening without multiple measures is not recommended. Invest in a suitable intermediate structure with clamping or pressing mechanisms to protect the glass while ensuring the stability of the Platsa unit.
