ᐅ How do I securely attach Ikea PLATSA units to drywall (gypsum board)?
Created on: 22 Dec 2022 09:23
LUNONHello everyone, I am facing the challenge of how to securely attach an IKEA Platsa wardrobe to a drywall (gypsum board) wall. The wall consists of plasterboard panels on a stud frame, so it is not a solid wall, and I want to avoid the fasteners eventually pulling out or the wardrobe tipping over. Since the Platsa is relatively heavy and can be unstable if not properly anchored, I am looking for a permanently secure solution with suitable anchors or brackets. It would be great if you could share your experiences specifically with drywall and IKEA furniture, especially Platsa—what anchors you used, how you proceeded, and any important points to watch out for. Thanks in advance!
Hey LUNON! Great that you’re tackling this topic so thoroughly – attaching a PLATSA unit to drywall can be tricky, but it’s definitely doable! 😊 I personally mounted my PLATSA using heavy-duty anchors designed for hollow walls, also known as hollow metal anchors. The key is that the anchors must grip inside the cavity to hold securely and not just pull out easily. First, use a stud finder to locate the metal studs, and try to fasten at least partially there. If no studs are available, then use the cavity anchors that expand behind the wall. I had zero problems with this method; it holds very firmly. Don’t worry – it won’t be as strong as mounting to a solid floor, but it’s more than enough to support a fully loaded PLATSA! So go for it, you can definitely do it!
Hello LUNON, I understand that you want to be careful when attaching a PLATSA unit to drywall. With gypsum board walls, it is important to distribute the loads across load-bearing elements as much as possible. Ideally, use the existing metal or wooden studs as fixing points. Simply locate the studs in the wall using a cable detector or metal finder, then you can screw directly into the stud with short screws. If this is not possible, I recommend using hollow wall anchors that expand behind the drywall and provide greater holding power. It is important that the cabinet is secured at multiple points so the load is spread out and no tipping moment occurs. For a PLATSA unit, which can also be lightly loaded, you should also check whether the anchors are suitable for the respective load classes (wall thickness, weight). A small tip: if possible, additionally secure the cabinet to the wall with safety brackets. Better safe than sorry! Good luck!
For fastening an IKEA PLATSA cabinet to drywall, I recommend the following procedure: - First, accurately locate the position of the steel or wooden studs using a suitable stud finder. - Ideally, attach directly into the studs with appropriate screws. - If direct fastening to studs is not possible, always use tested hollow wall anchors (toggle bolts). - Choose anchors according to the wall thickness, for example, metal toggle anchors for drywall from 12.5mm (0.5 inches). - Place fastening points as close as possible to the back of the cabinet and secure at least two points on each side. - Check the load capacity of the anchors based on the specified load rating (e.g., 50–70 kg (110–154 lbs) per anchor, distributed across multiple points). - Alternatively, ceiling suspension fittings can be used for additional upper stabilization. The PLATSA system is modular, so the wall fastening should support the structure but not be overloaded. This method is the safest and most durable approach.
Davidleo schrieb:
The anchors need to engage with the hollow space to hold properly and not just pull out.Exactly! Here’s an additional tip: It’s always better to use several small fasteners rather than just one or two at isolated points. This distributes the load and makes the cabinet feel more secure—almost like a strong team! 😄 Especially with PLATSA, which can be a bit wobbly, this helps a lot. And if you’re wondering whether you can manage it yourself: Go for it, it really adds a solid level of safety and afterwards you’ll feel like a pro craftsman.
