ᐅ How do I secure IKEA Platsa furniture to tile flooring?
Created on: 31 May 2023 14:07
LIAMFRA50
LIAMFRA50
31 May 2023 14:07
I want to fix my IKEA Platsa furniture onto tiled flooring and I’m facing some challenges where I hope to find tips and proven solutions here. The tiles are firmly installed and there are no grout lines where the furniture will stand, so I can’t simply drill into a grout line. My main goal is to secure the furniture safely and level without damaging the tiles. At the same time, the fixing system should be stable enough to prevent the furniture from tipping over or shifting, especially during everyday use with loads.
Does anyone have experience with how to effectively fix IKEA Platsa furniture onto smooth tiles? Which materials, anchors, or adhesives work well in this situation? Is there anything specific I should consider for the Platsa system? I look forward to your detailed tips or suggestions for alternatives I might not have thought of yet.
Jeanbar
31 May 2023 15:53
Hello LIAMFRA50,
Your question is very important because attaching furniture to tiles can quickly become problematic if you want to avoid damaging the tiles. First of all, you should know that drilling into tiles is generally possible but must be done carefully to prevent cracking.
Regarding your question:
- If you do decide to drill: Make sure to use a tile drill bit (diamond or carbide tip) and drill slowly, preferably at low speed and without applying too much pressure.
- For mounting, special expansion anchors or cavity anchors designed for tiled surfaces are suitable.
- Alternatively, construction adhesive or mounting glue can provide a good hold, especially if the furniture will bear only light loads.
With IKEA Platsa furniture, you have the advantage of modular side panels and carcass connections: it is quite practical to fix the furniture to the wall using brackets if there is a solid wall behind the tiles. In cases where the tiles are only a thin layer and there is a cavity behind them, a mounting foam or clamping structures could be an option.
In summary: Use a drill bit with the appropriate tip, light anchors, and screws. And if you prefer not to drill, use mounting adhesive or brackets attached to the back of the furniture.
If you have any further specific questions about installing the Platsa units—feel free to ask!
anfeteo
1 Jun 2023 09:17
Hello LIAMFRA50,
I fully agree with Jeanbar and would like to provide you with a brief guide on how to safely attach IKEA Platsa furniture to tiled walls without causing significant damage.
1. Preparation:
- Check whether there is a solid wall (e.g., concrete, masonry) or a cavity behind the tiles.
- If there is a cavity, use special cavity anchors or toggle bolts.
2. Drilling:
- Use a tile drill bit with a carbide or diamond tip.
- Keep the drill speed low; do not use hammer drill mode.
- Minimize dust at the drilling point by applying tape.
3. Fastening materials:
- Use expansion anchors for solid substrates.
- Use nylon or metal cavity anchors for hollow spaces.
- Choose screws that fit the anchor size.
4. Alternative fastening:
- Attach mounting brackets to the back of the furniture.
- Secure the brackets to the wall; use adhesive as additional support if drilling is not possible.
5. Adhesive options:
- Strong mounting adhesive (e.g., polyurethane-based adhesive) can be used to stabilize the furniture but does not replace mechanical fixing.
6. Tips:
- Distribute fastening points in several locations to better spread tension forces.
- After installation, apply waterproof silicone sealant to the drilled areas to prevent moisture damage.
I hope this overview helps you. If you carefully follow all these points, the furniture will remain securely in place and the tiles will stay largely undamaged.
kasan
2 Jun 2023 11:39
Jeanbar schrieb:
- If you really want to drill: Be sure to use a tile drill bit (diamond or carbide tip) and drill slowly, preferably at low speed and without applying too much pressure.
This is basically correct, but I find it surprising that drilling is recommended here without first considering the load-bearing capacity of the substrate behind the tiles.
Even if you use the tile drill bit properly, it won’t help much if the wall behind consists, for example, only of drywall or a thin material that won’t hold the anchor. You need to determine the substrate condition before choosing the installation method.
Additionally:
- Mounting adhesive is great, but for a piece of furniture like Platsa, which may be loaded (e.g., with drawers, clothes, or even small storage), I wouldn’t rely on adhesive alone, as it cannot reliably withstand lateral and tensile forces over time.
- An alternative solution would be to secure the furniture freestanding on a non-slip floor or with floor adhesive instead of riskily drilling into tiles.
In short: It’s better to carefully check the substrate before drilling and develop the best fastening concept rather than drill out of habit.
FLONE41
3 Jun 2023 18:26
kasan schrieb:
- Assembly adhesive is great, but for furniture like Platsa, which will be subjected to loads (e.g., drawers, clothing, or even small storage), I wouldn’t rely on it alone, as it can’t reliably handle lateral and tensile forces over time.
I can only confirm this from my experience. I once tried attaching Platsa furniture to tiles using only assembly adhesive – it held well at first, but after a while the furniture came loose, especially under load or when opening doors.
The following method worked better:
- Drilling through the tiles at suitable points (with great care and the appropriate drill bit).
- Using wall plugs that are suitable for the substrate.
- Then securing the furniture to the wall with sturdy metal brackets.
I know people prefer not to damage tiles, but for me, this provides the necessary safety. If you have a hollow wall, you can use hollow wall anchors or toggler bolts, as anfeteo already mentioned.
If you’re afraid of drilling, my recommendation is to try it first in an inconspicuous area with the drill, working very slowly and carefully. If the surface is too delicate, I would place the furniture freestanding on non-slip mats.
Of course, this isn’t a perfect solution, but for furniture used daily, safety is more important to me than a flawless appearance without drill holes.
