Hello everyone, I recently purchased some IKEA Platsa furniture and want to secure it safely and permanently on my laminate floor. The problem is that the laminate is quite smooth, and I’m concerned that the furniture might slide or shift under load. At the same time, I don’t want to cause any permanent damage to the floor since the laminate is still relatively new.
My question: What options are available to fix PLATSA cabinets or shelves so they stand stable without using invasive floor fastenings like screws? What has proven effective in practice, especially when you don’t want to put a carpet underneath? Are there special adhesives, anti-slip mats, or other techniques that work well?
I look forward to your experiences and recommendations.
Thank you for the details; that clarifies a lot.
In your case, my recommendation would be a combination of:
- Non-slip pads under the furniture legs to prevent slipping.
- Light wall fasteners that use minimally invasive drilling, such as small angle brackets or clamp holders, if your walls are suitable.
If you’re concerned about holes, you could consider furniture connectors that don’t require drilling—for example, ones that hold the furniture against the wall by pressure—but success here depends heavily on the wall surface.
Also important: if the furniture is assembled from multiple modules, make sure the units are well connected to each other. IKEA offers connector fittings that help reduce tipping.
This way, you minimize the risk of furniture tipping over or sliding without damaging the laminate flooring.
benon schrieb:
If you're afraid of making holes, you might consider using furniture connectors without drilling – such as those that hold on the wall by pressure, but success here strongly depends on the wall surface.I completely agree. I had similar concerns before, and indeed pressure-fit connectors worked well for me—they hold firmly on smooth wallpaper. However, if the wall is rougher (like plaster), it becomes more challenging.
What also worked well for me was using so-called furniture stoppers (small wedges that you place between the furniture and the wall). These also don’t require drilling and aren’t a permanent solution but serve as a useful addition.
Fupabo schrieb:
I wouldn’t really call the modules freestanding either; they are simply placed close together, but these dimensions do feel somewhat unstable on smooth laminate.I’ve experienced that too – the modules feel more stable together, but when pressing on them, you can still tell there’s a risk of tipping. In addition to the tips already mentioned, I can recommend the following:
- Connecting the individual modules with metal brackets underneath. This creates a stable unit.
- Using felt pads with rubber backing as a base, which increases grip on laminate flooring.
I also find it helpful to modify the legs or feet of the furniture slightly. Some people cut small rubberized washers or self-adhesive non-slip pads to get even better traction.
None of these methods is perfect on its own, but combined, you can achieve quite acceptable stability.
