Hello everyone, I recently purchased some IKEA Platsa furniture and want to secure it safely and permanently on my laminate floor. The problem is that the laminate is quite smooth, and I’m concerned that the furniture might slide or shift under load. At the same time, I don’t want to cause any permanent damage to the floor since the laminate is still relatively new.
My question: What options are available to fix PLATSA cabinets or shelves so they stand stable without using invasive floor fastenings like screws? What has proven effective in practice, especially when you don’t want to put a carpet underneath? Are there special adhesives, anti-slip mats, or other techniques that work well?
I look forward to your experiences and recommendations.
This is really an important question, especially because laminate flooring can be sensitive to screws or adhesives.
I have PLATSA furniture on laminate myself and can say from experience that non-slip mats (those thin rubber mats placed under rugs) often work quite well. They provide grip without damaging or sticking to the surface. However, dust can sometimes accumulate underneath, so you might need to peel off and clean the mats every few months.
What I haven’t tried but am considering are furniture floor protectors with adhesive backing. That might offer additional stability while also being gentle on the surface.
I’d also be interested to hear if anyone has specific tips that go beyond the usual anti-slip solutions.
I recommend using special double-sided carpet tape. It usually holds quite well but can generally be removed without leaving residue if done carefully. Alternatively, you can use furniture fasteners from Ikea to secure items to the wall. This usually provides enough stability.
To securely fix IKEA PLATSA furniture on laminate flooring, the following points should be considered:
- Direct screwing into the floor is not recommended due to the material properties of laminate.
- Anti-slip mats made of natural rubber or acrylic are proven solutions and also protect the floor.
- Double-sided carpet tape can be an alternative, but its residue-free removal should be checked beforehand.
- If the furniture can be fixed to the wall, special angle brackets or IKEA’s own wall fasteners are the safest option for stabilization.
I recommend initially placing the furniture on anti-slip mats on the laminate and additionally securing it with wall brackets. This provides maximum stability without damaging the laminate.
Your concern is completely understandable. I looked into this topic some time ago and have gathered a few insights that might help you:
1. Preparation: Laminate flooring is sensitive to moisture and pressure. Avoid products that are screwed or glued while damp, as this can cause the laminate to swell or become damaged.
2. Anti-slip mats: I recommend mats about 2-3 mm (0.08-0.12 inches) thick; these distribute weight better and effectively reduce slipping. Make sure they are made from materials that don’t leave chemical residues on the laminate.
3. Furniture fasteners to the wall: Since PLATSA units can be somewhat unstable, securing them to the wall is highly recommended. Use the original fittings provided or sturdy brackets. It is important that the fastening is anchored into solid masonry, not just loose or plaster.
4. Double-sided tape: Some people use it, but I advise caution. While it initially holds well, removing it often leaves adhesive residue that can stain the laminate.
5. Alternative: Furniture pads with rubber rings on the legs. They increase friction at contact points, making sliding less likely.
One important follow-up question: How tall and heavy are your PLATSA units? Are they free-standing or placed in a corner? This will help provide more precise advice.
Filippo schrieb:
One important follow-up question: How tall and heavy are your PLATSA furniture pieces? Are they freestanding or placed in a corner? This will help provide more precise advice.Thanks for the follow-up! The furniture pieces are each about 2 meters (6.6 feet) tall and consist of several connected modules that weigh around 70–80 kilograms (154–176 pounds) in total. They are mostly placed against the wall, sometimes in a room corner, but usually without direct wall support because the room is quite large and I want to avoid making too many holes in the wall. I wouldn’t really call the modules freestanding either, as they are lightly placed next to each other, but these dimensions do seem somewhat unstable on smooth laminate flooring. A reversible solution without drilling into the floor is important to me, ideally with minimal use of wall anchors. I hope this helps.
