ᐅ How do I secure Ikea Pax wardrobes to drywall partitions?
Created on: 21 Oct 2016 18:23
narkeo
narkeo
21 Oct 2016 18:23
I am planning to install an Ikea Pax wardrobe in my bedroom, but the walls there are drywall only—no solid walls or timber studs. My question is quite specific: How can I securely and permanently fix an Ikea Pax wardrobe to drywall?
It is important to me that the wardrobe is stable, as it will be loaded with clothing and weight accordingly. Are there special anchors or fastening methods that have proven effective? Do I always need to install a wooden batten behind the drywall, or are good drywall anchors sufficient?
Additionally, it would be helpful to know if the standard Ikea Pax assembly instructions are suitable for this, or if there are modified procedures.
Thanks for your tips and experiences!
harold
21 Oct 2016 19:05
Hello narkeo,
First, a clear answer upfront: To securely attach an Ikea Pax wardrobe to a drywall partition, you generally need an additional sturdy framework behind the drywall board. Standard drywall anchors alone are usually not sufficient for long-term stability.
Here is a brief step-by-step explanation:
- First, check through a small opening whether there is a wooden batten or metal stud behind your drywall. This is where you can find direct support.
- If there is no stable framework present, it is recommended to screw a wooden batten horizontally onto the wall. This batten must be attached to the load-bearing wall studs, meaning behind the drywall through an opening or from the other side.
- For fastening the Pax wardrobe profiles, use wood screws in the batten; these are significantly more load-bearing than anchors in drywall alone.
- If it is not possible to install the batten securely into the wall structure, you will need to resort to heavy-duty anchors (e.g., metal toggle bolts or special metal anchors designed for drywall in load-bearing areas). However, these solutions are more of a compromise and less permanent.
- In any case, the weight distribution should be considered—use multiple fastening points and avoid supporting the wardrobe only at the bottom against the wall.
Summary: Drywall screws or simple plastic anchors are usually not enough. A stable framework or special heavy-duty anchors provide a secure solution. Ikea’s instructions often assume solid walls, so adjustments are necessary.
I hope this gives you a good orientation!
BARSAN
22 Oct 2016 08:44
I would always recommend using wooden battens behind the drywall. Screw the battens to the studs, then you can securely attach the Pax wardrobe there.
GLORIA
22 Oct 2016 10:17
harold schrieb:
In any case, you should consider weight distribution by using multiple fixing points and avoid supporting the cabinet only at the bottom against the wall.
That is absolutely correct. Drywall partitions typically consist of a gypsum board with a thickness of 12.5 mm to 15 mm (0.5 to 0.6 inches) mounted on a metal or wooden stud framework. Without a load-bearing substructure, it is not possible to securely support reasonable loads.
Therefore, I recommend the following approach:
- Locate the position of the wall studs within the drywall.
- Attach a horizontal wooden batten (at least 40 x 60 mm (1.5 x 2.4 inches)) to these studs.
- Fasten the Ikea Pax profiles to this batten using wood screws.
Additionally, there are specialized anchors available on the market, such as metal toggle anchors or toggle bolts, which are designed for point loads of up to approximately 50 kg (110 lbs). However, I would not rely solely on these for a fully loaded Pax wardrobe.
Unfortunately, the Ikea assembly instructions do not adequately address this specific situation and mostly assume solid walls, so some DIY initiative is necessary.
In conclusion: A combination of multiple fixing points, a sturdy substructure, and high-quality screws is crucial for safety.
