ᐅ How can I securely fasten Ikea Pax furniture without damaging the wall?
Created on: 29 Jul 2021 17:03
Johnsu
Hello everyone, I am planning to install my Ikea Pax wardrobes in the apartment and hope someone here can help me. My main question is: How can I securely fix my Ikea Pax furniture to the wall without causing damage to the wall? Specifically, I am interested in which fastening methods and materials are suitable to stabilize the wardrobes, especially since they are quite tall and heavy, and how to avoid common wall damages like cracks, holes, or plaster chipping. Are there any special types of wall anchors, mounting accessories, or techniques you would recommend? Most of the walls in the apartment are drywall, but some areas have concrete or brick. Thanks in advance for your advice!
Johnsu
30 Jul 2021 11:52
BARSAN schrieb:
For drywall: metal toggle anchors. For concrete: hammer-in anchors or chemical anchors.
Thanks, that already provides clear guidance. My apartment mostly has drywall, but in the kitchen/dining area there is also a load-bearing brick wall. So, is it advisable to use different types of anchors for the different wall types, or is it sufficient to use the strongest type of anchor everywhere? Also, I wonder if the Ikea wall fixings are really adequate, or if it’s better to rely entirely on your own mounting materials? Are there any experiences on this? I want to secure the cabinets as safely as possible without risking any need for wall repairs later on.
PECLARISSA
30 Jul 2021 14:08
What a great discussion here – I love it when it comes to solid fixture installations! 🙂
A few thoughts: I would never use just standard screws on drywall, as the wall could easily give way. It’s better to invest a bit more in metal toggle anchors. For brick or concrete walls, something more robust is needed, as jaanda and BARSAN mention – such as chemical anchors or hammer-in anchors.
Johnsu, if you have the option, try to fix the cabinets to wall studs with wood backing behind; this provides a secure hold, similar to reinforced concrete – or attach a wooden batten in front as a buffer and even load distributor.
This can be done easily without damage, especially if you proceed carefully. And honestly: a bit of finesse helps a lot – don’t drill too hastily, measure precisely, and don’t choose a drill bit that’s too large.
This not only ensures stability but also boosts the success factor for your living space! 😉
Joshbe
30 Jul 2021 18:33
Johnsu, regarding your specific question: Yes, it is definitely advisable to choose wall plugs according to the type of wall. There is no universal wall plug that works for every material because density and load-bearing capacity vary. So: metal toggle anchors for drywall, and expansion or chemical anchors for brick and concrete.
Regarding fastening materials: Ikea’s own fittings are functional but often of lower quality compared to standard wall plugs and screws that are certified for the specific wall type. Especially with heavy furniture, it’s better to use high-quality materials.
Additionally, I recommend using a spirit level when marking the drill points and pre-drilling with a drill bit that is sufficiently small. This helps prevent damage and ensures a more secure fixing.
Ianlau
31 Jul 2021 09:22
tolokau schrieb:
When working with drywall, it’s always a good idea to use an additional wooden batten as a mounting aid, to which the cabinet can then be screwed.
This is truly a simple and very effective tip that I recommend to everyone. Especially with large and heavy Pax wardrobe combinations, the wooden batten provides significantly better load distribution.
Make sure to attach the batten with appropriate anchors and screws so that it is securely mounted and load-bearing. Afterwards, you can fasten the cabinet to it with shorter screws, which protects the wall considerably.
Additionally, I recommend marking the wall before installation to identify where the studs or framing members are located. A stud finder works very well for this, even though it might be an extra investment for some.
jaanda
1 Aug 2021 07:41
Johnsu schrieb:
So, is it advisable to use different anchors for different wall types, or is it enough to use the strongest anchor type everywhere?
For a secure and lasting fix, it’s always better to choose anchors that match the wall material. A heavy-duty anchor that is too aggressive or too large for drywall can damage or even crack the wall. Conversely, anchors designed for drywall will fail in brick or concrete.
Joshbe schrieb:
Especially for heavy furniture, it’s better to use high-quality materials.
I agree with that. IKEA hardware is convenient, but materials available from specialist suppliers are often more durable, which improves safety and prevents damage in the long run.
One more tip: Check the wall materials before installation since a single property can have different wall types. This way, you can plan the installation well and avoid damage.
