ᐅ How do I securely mount Ikea Metod wall cabinets on wooden paneling?
Created on: 10 Aug 2017 18:23
ELSIFI
Hello everyone, I am currently facing the challenge of mounting Ikea Metod wall cabinets on a wall with a wooden paneling. The paneling consists of relatively thin wooden panels fixed to a mounting framework. Directly behind the panels, there is no solid masonry but rather a cavity or insulation.
My question is: How can I securely and stably attach the Metod wall cabinets to this wall? Which anchors or fastening methods are suitable to support the weight of the cabinets and prevent them from falling after some time?
Additionally, I am interested to know whether it makes sense to install an additional support board or metal profile behind the wooden paneling, or if there are special heavy-duty fasteners designed to work directly with this wall construction.
I look forward to detailed advice and practical solutions.
flota
11 Aug 2017 14:03
Regarding the installation height and load distribution, I recommend carefully studying the Ikea instructions and not exceeding the maximum load per mounting point.
Additionally, to be on the safe side, you can provide several mounting points on the carrier plate to ensure optimal load distribution.
PLOMA
11 Aug 2017 15:37
chenValeri schrieb:
Another option, if you don’t want a support board, would be heavy-duty anchors or special heavy-duty dowels, provided you can target the beams precisely.
That is theoretically correct, but caution is advised due to the cavity behind the wooden cladding. Even precisely targeted heavy-duty dowels can loosen over time, especially if the beams are only 40x60mm (1.6x2.4 inches) in size.
The cross beams can support a lot, but the combination of hanging load plus possible vibrations or vibration-related stress on the thin panel wall can become problematic.
Therefore, I explicitly recommend using a support board as best practice for the loads of Ikea Metod cabinets. This ensures long-lasting stability and prevents damage to the wall or the cabinets.
ELSIFI
12 Aug 2017 08:22
Great, your detailed posts have been very helpful. I will follow the recommendation to install a plywood carrier board and screw it securely onto the wooden beams. For the appearance, I will choose a suitable color and ensure a neat surface finish.
Many thanks to everyone for the helpful, detailed, and practical answers!
