ᐅ How do I securely attach IKEA Metod kitchen cabinets to drywall?
Created on: 10 Jan 2024 08:17
Nonson
Nonson
10 Jan 2024 08:17
I am currently facing the challenge of how to securely and permanently attach my Ikea Metod kitchen cabinets to drywall. Since my kitchen walls are not solid but only drywall, I am concerned that the cabinets might not hold safely or could come loose over time.
I am particularly interested in which types of anchors or fasteners you would recommend, whether special plastic or metal anchors should be used, and how to take the weight of the cabinets into account.
Additionally, it would be helpful to know if you suggest any special precautions when mounting the hanging rails on drywall, such as reinforcements behind the wall or specific types of anchors. I have the Ikea Metod wall cabinets, which I plan to hang in two rows side by side.
I look forward to your experience and advice – thank you in advance!
GiRoyce
10 Jan 2024 08:46
Hello Nonson,
your question is really important because drywall partitions are not generally designed to carry heavy loads without precautions.
Basically, Ikea Metod kitchen cabinets are hung on a metal mounting rail that distributes the load across several points. With drywall, it is essential to ensure that the rail is screwed into either timber studs or metal wall studs, not just the drywall panels themselves.
If you cannot locate studs, you should use high-quality metal expansion anchors or special drywall metal anchors. These provide better holding power than simple plastic anchors. Still, the weight of the cabinets must be considered: as a rule of thumb, do not hang more than two empty cabinets on a single rail without additional reinforcement.
Another option is to install a backing support, such as a wooden board behind the drywall (if possible), or to mount the rail directly onto a reinforced wall section. Feel free to ask if you can provide more details about your wall construction.
Best regards!
Dilen
10 Jan 2024 10:03
Hello Nonson,
to answer your question as thoroughly as possible, I would like to go through the most important aspects step by step.
1. Wall structure check: First, you need to carefully examine the composition of your wall. Interior walls with drywall often have metal or wooden studs – usually spaced 60cm (24 inches) apart. Ideally, you can screw the Metod mounting rail directly into these studs. This way, the weight is transferred directly to the load-bearing structure.
2. Fastening materials: If there are no studs or you cannot reach them, you can use drywall metal anchors that clamp behind the panel. These are rated for higher loads. Plastic anchors are not strong enough in this case.
3. Caution with load distribution: Ikea Metod cabinets, including contents, can weigh several tens of kilograms. It is not sufficient to rely on drywall alone. Ideally, install a horizontal wooden or steel support behind the panel or inside the wall, onto which you can screw the mounting rail.
4. Avoiding shear forces: Sometimes it helps to secure the top screws of the rail and additionally prevent lifting at the bottom with wooden battens.
5. Experience: Do you already have a detailed assembly instruction from Ikea? It provides guidance but is often designed for solid walls.
Could you tell me how thick your drywall panels are (commonly 12.5mm (1/2 inch)?) and exactly what is installed behind the wall?
This way, I can offer you more specific advice.
Joshbe
10 Jan 2024 11:29
In summary, the following points apply for securely attaching Ikea Metod kitchen cabinets to drywall (gypsum board) walls:
- The ideal attachment is achieved by directly screwing into the wall studs (wood or metal profiles).
- The load is distributed via the Metod hanging rail, which is essential for stability.
- If no studs can be reached, special drywall metal anchors designed to carry heavy loads should be used.
- The drywall panel must be at least 12.5 mm (0.5 inches) thick.
- Additional reinforcement behind the wall (wooden beams, metal profiles) significantly increases load-bearing capacity.
- The mounting hardware must be rated for the full weight of the kitchen, including contents (dishes, food).
Recommendation: Measure to locate the studs and use anchors accordingly. Otherwise, install a substructure and attach the hanging rail to it.
Please keep in mind that drywall alone is not sufficient to support heavy kitchen units without reinforcement.
blapau
10 Jan 2024 14:12
I would like to add that using so-called hollow wall anchors or toggle bolts is the best solution for fastening to plain drywall without studs. These anchors expand behind the drywall and provide significantly higher load-bearing capacity than simple plastic anchors.
However, it is important to pay close attention to the load capacity of each anchor to avoid overloading. I also recommend mounting the rail with multiple anchors spaced according to the existing wall studs to prevent load concentration.
Another tip: Before screwing in, mark the positions of the studs using a stud finder (metal and wiring detector) to ensure the best possible fastening points.
Nonson
10 Jan 2024 16:35
Dilen schrieb:
Can you tell me how thick your drywall sheets are (usually 12.5 mm (0.5 inches)?) and what exactly is installed behind the wall?
Thanks for the detailed answers so far! The drywall sheets are indeed the standard 12.5 mm (0.5 inches) thickness. The wall has metal studs spaced about 60 cm (24 inches) apart, but unfortunately, I don’t have an exact layout of their locations. There is no wooden framework, only the metal profiles serving as wall supports.
I’m wondering if I can simply screw the Metod rail directly into these metal studs or if special screws are required? And how can I ensure that the screws hold securely in the metal profiles and that the load is supported long-term?
I want to avoid bending or damaging the metal studs. Additionally, I am unsure how much load the drywall sheets can actually transfer at those points.
