ᐅ How do I install IKEA Metod cabinet doors on uneven walls?
Created on: 11 Mar 2023 08:37
diusdi
diusdi
11 Mar 2023 08:37
I am currently facing the problem of securely attaching IKEA Metod kitchen doors to my base cabinets, but unfortunately, the walls and the substrate are not completely even. The irregularities are quite noticeable, causing the doors to either stick when closing or not align flush.
My question is specifically for those who have experience or a suitable solution: How can Metod doors be optimally mounted on uneven walls or substrates so that the doors can be reliably adjusted and remain stable? What tools or materials (e.g., sealing profiles, washers, special hinges) are recommended, and what approach has proven to be practical? Are there any tricks to ensure that despite uneven walls, the gap between the door and the cabinet body stays consistent and no unwanted gaps appear?
I would greatly appreciate detailed advice, as I want to avoid having to redo the entire installation later.
JORDON
11 Mar 2023 09:15
Hey diusdi, great question! 😊 Uneven walls can be really frustrating when installing Metod doors, but with a few tricks, you can manage it. What worked really well for me were small plastic or wooden shims placed behind the hinges to help the doors sit at the right angle. Sometimes it also helps to tighten the screws only lightly by hand, then slowly move the door into the correct position before fully tightening. Adjusting with the built-in hinge settings is pretty clever too – you can fine-tune the fit at several points. If there are still large gaps, we’ve used thin sealing strips to mask small unevenness. So don’t worry, with a bit of patience it will work out! And keep in mind: it’s normal to have a few attempts before everything runs smoothly 😉
kaubi
11 Mar 2023 11:42
Hello diusdi, your question touches on a key issue when installing IKEA Metod kitchens on uneven surfaces. In short: the hinges are basically designed for slight adjustments, but these often aren’t enough for significant wall irregularities. Therefore, I recommend the following to achieve secure and permanently stable doors:
- First, measure very precisely how uneven the substrate and the cabinet sides are – using a spirit level and ideally a straightedge.
- Ideally, you can adjust the base cabinets yourself slightly, for example with height-adjustable furniture feet, to compensate for differences in the floor.
- If the hinges on the wall side protrude too far, you can use mounting plates (spacer plates) placed between the cabinet wall and the hinge. These come in various thicknesses and help pull the door out from the wall so it closes flush.
- Make sure to properly adjust the hinges using the 3D adjustment (height, lateral, and depth adjustment). This allows you to finely tune the door despite minor wall irregularities.
- For larger gaps, an additional furniture seal or a thin rubber strip for cushioning may help, which also keeps dust out.
Some professionals also recommend temporarily mounting the doors and loosening the hinges as much as possible with a stronger Torx screwdriver to fully reset and readjust them.
Do you have unevenness specifically on the wall side or on the cabinet sides? And how pronounced is it? The more accurately you describe this, the more precise the recommended installation procedure can be.
JORDON
12 Mar 2023 14:29
kaubi schrieb:
Some tradespeople also recommend temporarily installing the doors and loosening the hinges as much as possible with a stronger Torx screwdriver to allow complete realignment.
That’s exactly what I did! If you simply hang the doors loosely without fully tightening the screws, the whole system becomes much easier to handle. Personally, I first bent the upper hinge side so the door sits firmly against the cabinet body, then adjusted the bottom until everything was nice and flush.
kaubi schrieb:
If the hinges on the wall side stick out too far, you can use mounting plates (spacer plates) placed between the cabinet and the hinge.
I can only recommend using spacer plates, especially when the wall shows its usual quirks. These small plates are often worth their weight in gold to avoid frustration with misaligned doors. 😊
