ᐅ How can I install IKEA Metod cabinet doors so they operate quietly and last a long time?
Created on: 11 Mar 2022 08:23
selami63
I recently installed a kitchen with Ikea Metod cabinets including doors. I noticed that the doors warped slightly after a short time and sometimes make loud banging or scraping noises when closing. My question to the experienced DIYers here: How can I attach Ikea Metod doors so that they close quietly and, above all, remain stable and durable in the long term?
I am looking for a method or tips to both minimize noise and improve the durability of the door fittings. Are there special mounting materials, hinge adjustments, or other tricks that work particularly well with Metod doors?
I look forward to your experiences and advice!
Elias
12 Mar 2022 08:12
selami63 schrieb:
Some soft-close hinges allow adjustment of the damping strength. Are there any practical recommendations on whether to set the damping stronger or softer to improve durability?
In my experience, setting the damper slightly softer results in greater longevity because it distributes the force more gently.
A damper set too strong can place more stress on mechanical parts over time. However, this also depends on the door weight and frequency of use.
Lidan56
12 Mar 2022 08:33
Increase the damping setting for heavy doors and high usage.
For lighter doors, a moderate setting is sufficient, which helps protect the mechanism.
warrenka57
12 Mar 2022 08:57
I like how everything has developed here.
One small addition:
For those who want to be on the safe side, the door should not only be adjusted once after installation but the adjustment should be checked periodically, especially after extended use.
Durability and silent operation, in my opinion, are a combination of proper installation, high-quality materials, and regular maintenance.
selami63
13 Mar 2022 09:18
Thank you all for the helpful contributions.
For those interested, here is a summary of what I have learned:
- Adjust the hinges of the Metod doors correctly in all three dimensions (up/down, sideways, depth) to ensure the doors sit flush
- Switch to soft-close hinges, preferably choosing high-quality ones
- Add rubber buffers at the door stops to reduce noise
- Replace screws with higher-quality versions to ensure durability
- Regularly (about every 6 months) check, readjust, and, if necessary, lightly lubricate the hinges
- Set the soft-close mechanism slightly softer to protect the hardware
If anyone has additional tips – feel free to share! For me, this results in a much better outcome than with the standard installation.
anken
13 Mar 2022 09:30
Very good summary, selami63.
I would like to add that in kitchens with high humidity (e.g., near the sink), wooden or MDF elements sometimes swell. This can cause warping of the doors.
In addition to secure installation, surface treatment or moisture protection for the doors is recommended.
