ᐅ How can I install BILLY shelves in rental apartments without using wall anchors?
Created on: 24 Sep 2023 08:13
Hauplo
Hello everyone, I am currently facing the problem of installing my IKEA BILLY shelves in my rental apartment, but I want to avoid the usual drilling and wall plugs because, on the one hand, I don’t want to damage the walls, and on the other hand, my lease agreement clearly states that no structural alterations are allowed. Are there ways to mount the BILLY shelves securely and stably without using wall plugs or damaging the wall? I am open to all practical suggestions, whether special adhesive systems, specific constructions, or alternatives that still make the shelves stable. My main goal is to install the shelves so they won’t tip over and remain safe, without leaving marks on the wall. Thanks in advance for any tips and experiences!
Lucien
24 Sep 2023 14:17
In addition to the previous suggestions: IKEA BILLY shelves come with standard mounting points on the back designed for screws. Without using wall anchors, the shelf can only be secured to the wall by non-permanent methods.
A professional alternative would be to install custom-made protective panels on the wall, on which the shelf can then be placed to minimize abrasion and pressure marks. Combined with anti-slip mats under the shelf, this can increase stability.
However, permanent safety without wall mounting is difficult to guarantee, so special caution is advised with heavy or large shelves that could tip over.
Hauplo
25 Sep 2023 07:45
Thanks already for the previous answers. To add some more information:
The shelf will mainly hold books, so it will generally carry medium to heavy weight. The apartment has standard ceiling heights of about 2.55 m (8 ft 4 in) – unfortunately, it is not possible to install a tension rod between floor and ceiling because the ceiling has multiple layers of painted plaster that must not be damaged.
theo63 schrieb:
Is there really no way to stabilize the shelves on the floor without wall mounting? For example, with non-slip pads or furniture clamps between the top of the shelf and the ceiling?
Furniture clamps or contact with the ceiling are unfortunately not practical here, as the shelf would damage the ceiling.
Does anyone have experience with special wall adhesive methods or DIY solutions that can support somewhat heavier weights? I am thinking, for example, of industrial adhesives or double-sided special tapes that can be removed without leaving residue.
kasan
25 Sep 2023 10:23
This is an important detail. Industrial adhesives or double-sided tapes may seem tempting at first, but the actual stresses on a fully loaded Billy bookcase are considerable.
Hauplo schrieb:
For example, I am thinking of industrial adhesives or double-sided specialty tapes that can be removed without leaving residue.
Besides load capacity, the issue of residue-free removal is particularly relevant here. Many adhesives leave stubborn residues and can cause problems when moving out later.
In my experience, such tapes are only suitable for decoration or very light shelving, if at all. I would rather consider tension poles, although that might be difficult with your ceiling, or opt for a lower bookshelf that can be securely supported in other ways.
JAFUHAU
25 Sep 2023 13:56
Some time ago, I encountered a similar problem and decided to use so-called "corner braces" with a very strong adhesive surface. They secured the shelf against tipping over without the need for drilling.
The shelf wasn’t fixed firmly to the wall, but it was stable enough for everyday use and didn’t leave any marks on the wallpaper. Maybe this could be an option for you if industrial adhesive and tension rods are not suitable alternatives?
Aimee
26 Sep 2023 08:14
Adhesives often work best for light to medium loads.
Furniture brackets with adhesive backing or heavy-duty adhesive tape are practical options.
A combination of an anti-slip mat and adhesive brackets can provide a good compromise.
