I am planning to assemble one or more IKEA Malm dressers, but the space in my apartment is quite limited, which makes the assembly more difficult. The dressers are relatively large, and although the instructions are clear, I am worried that I might get confused or damage some parts while putting them together in my small room with very little room to move.
Do you have any tips or strategies on how to best approach assembly when space is very limited? Are there any tricks for partially pre-assembling the dressers or ways to plan the build more cleverly to save space?
I would appreciate any experience or practical advice, especially from those who have assembled Malm dressers in small rooms. Thanks in advance!
medo68 schrieb:
Do you have any tips or strategies for the best approach when space is very limited?Hey! I think anyone who has dealt with furniture and tiny rooms knows this well. My tip: Try unpacking all the parts completely first and lay them out neatly on the floor – this way, you can easily see which pieces belong together without having to move everything around randomly.
Also, if you have a sturdy surface (like a large table or solid boxes), it’s best to assemble the dresser while it’s lying down – on its back, as shown in the instructions. This means you need less vertical space and can screw everything together more comfortably.
Finally, keep a positive attitude! ;-) Limited space can be frustrating, but with a bit of patience, you’ll get through it. 🙂
To approach the topic more systematically: I recommend measuring the room carefully before assembly. This allows you to determine where the chest of drawers will be placed later and also find a suitable area for assembly, even if it is only temporary.
A proven method is to carry out the assembly step-by-step and avoid spreading all parts out completely, placing only as much on the floor as necessary.
Another option is to assemble components in "modules," meaning putting together individual parts of the chest (e.g., side panels, back panel, drawers) separately and then connecting them afterward. This reduces the space needed during the process.
Finally, a tip: Make sure you have all the required tools within reach to avoid unnecessary moving around.
Hello medo68,
Since you specifically mentioned the Malm frame and the limited space, here are some practical tips from my experience:
1. Preparation: Take enough time and unpack the parts in a room that is as empty as possible (for example, a hallway if it is wide enough).
2. Assembly lying down: As chen67 already mentioned, assembling the large pieces is often easier when you build them lying on their back. This requires less vertical space.
3. Modular approach: Some customers have reported building the dresser in two stages – first the main frame and then the drawers separately. This can save a lot of space, especially if the drawers are prepared outside the frame.
4. Using doors as an assembly surface: Some doors or large, sturdy boards can be used as a work surface, which often helps save some maneuvering space.
5. A second person can be helpful but is not absolutely necessary.
Good luck with the assembly, feel free to reach out if you need more details!
Brian schrieb:
Some customers have reported building the dresser in two stages – first the main frame and then the drawers separately.Thanks for the tip, Brian! That makes sense to me. I’m just wondering if attaching the drawers to the carcass later might be tricky if there’s limited space.
Does anyone have experience with how tight the installation gets at that point? Is there enough clearance, or should the drawers be fully assembled first and then the carcass built around them?
Also, I’m considering assembling the dresser in the middle of the room before moving it to its final position – do you have any advice on that, or would it risk damaging the parts?
medo68 schrieb:
Does anyone have experience with how tight the installation will be at that spot?You assemble the drawers completely separately. The cabinet is stable once you simply slide the drawers in.
If your room allows, build it in the middle first and move the dresser into place at the end.
This is standard practice and works without any issues.
