Hello everyone, I’m currently facing the challenge of mounting IKEA Platsa units on a wall that isn’t perfectly straight. The wall has slight deviations in several areas, which makes attaching the cabinets difficult because the modules don’t sit flush or end up crooked.
My question is: What is the best way to install IKEA Platsa on uneven walls without the furniture becoming unstable or looking untidy afterward? Are there specific techniques or tricks to compensate for irregularities? I have already considered using thin wedges, special fasteners, or adjustments on the sides, but I’m unsure how to do this properly or if it is even possible within the system’s design.
Thanks in advance for your advice!
ECKEHARD4317 May 2022 09:45Siflo schrieb:
In case of significant unevenness, it is advisable to install a preliminary substructure, such as battens, to create a level mounting surface.Thanks for the tip about the substructure; that sounds like a practical solution for particularly uneven walls. Unfortunately, the space behind the cabinets is quite limited, so I can’t build up too much. Do you have a recommendation on the maximum thickness this substructure should be without losing too much storage space? Or perhaps alternatives that take up less room?
ECKEHARD43 schrieb:
Would you have a recommendation on how thick this substructure should be at most, without losing too much storage space?In my experience, wooden battens between 10 and 15 mm (0.4 to 0.6 inches) thick are sufficient for the substructure to compensate for unevenness while largely preserving storage space. It is important to align these battens precisely using a spirit level to create a flat surface. For minor wall irregularities, using flexible shims can be preferable to avoid losing too much space.
KAMERON schrieb:
In my experience, battens that are only 10 to 15 mm (0.4 to 0.6 inches) thick are sufficient for the substructure to even out irregularities while largely preserving storage space.I agree with that. Here’s a little tip: if you paint the battens in a matching color, they become almost invisible once installed – a combined solution of stability and design. And if you like, you can even use sealant to disguise visual transitions. Good luck with your project!
