ᐅ How do I assemble IKEA PLATSA when it cannot be secured to a wall?
Created on: 2 Jan 2024 10:23
TE_NEOHello everyone,
I’m facing the challenge of assembling an IKEA Platsa system where direct wall mounting is not possible. Due to the building conditions — I cannot drill or use suitable anchors — I am looking for secure alternatives to assemble the cabinets so that they remain stable and safe to use without tipping over.
I have read that some users place the furniture freely in the room and connect it with other elements, but I’m unsure if this provides sufficient stability for Platsa. Are there specific methods to fasten the modules to each other to increase their stability? For example, would using plinths, base plates, or additional connectors be beneficial if wall anchoring is not an option?
I would really appreciate any experience or step-by-step guidance on how to assemble IKEA Platsa so that it stands securely and remains durable in everyday use without wall fastening.
Thank you in advance!
TE_NEO schrieb:
I am facing the problem of installing an IKEA PLATSA system where direct wall mounting is not possible.If no wall mounting is possible, the best option is to securely connect the modules together using the supplied connectors.
- Place the unit firmly on the floor
- Choose the widest possible base structure
- Store heavy loads at the bottom
Marlenepa2 Jan 2024 12:17Hello TE_NEO,
You have described your situation very well. In general, PLATSA is designed to be especially secure when attached to the wall, as the cabinets tend to be quite tall and slim. However, if wall mounting is not possible, you can consider the following:
- Ensure a level and stable floor as a foundation.
- Distribute the weight as evenly as possible in the lower areas.
- Use the included connecting fittings to join the individual modules as firmly as possible.
- Optional: Floor clamps or baseboards, which Ikea also offers separately, can increase stability.
Another option is to use sturdy wooden or MDF base plates for the modules to stand on, connected to each other to make them less likely to tip over. Screws or strong connecting brackets should help with this.
If you like, I can also explain in more detail how to properly make these connections.
Marlenepa schrieb:
you have described your situation very well.It is important to note that without wall mounting, the risk of tipping remains higher, especially with large and tall PLATSA units.
A practical alternative can be securing the modules to each other using sturdy metal brackets, preferably on the sides or the back, to eliminate any pivot axis.
Additionally, the weight should be shifted downward, for example, by using heavy fillings or placing weights in the lower compartments.
Finally, make sure that no strong pulling or pushing forces act on the furniture, as it can tip over more easily without wall mounting. An additional floor anchoring, if possible, would be even more effective from a structural perspective.
pikin schrieb:
It is also important to note that without wall anchoring, the risk of tipping remains higher, especially with large and tall PLATSA units.Thank you for the advice, that’s a good point. In my case, the modules will be about 2 meters (6.6 feet) tall, so definitely quite large.
Do you have any recommendations on which type of floor anchoring works best if I cannot make permanent drillings? Are there specific clamping or tensioning mechanisms that can be used instead to provide additional floor stabilization?
I would also like to be able to remove or relocate the furniture with as little residue as possible.
TE_NEO schrieb:
Do you have any recommendations on which type of floor fixing works best if I cannot make permanent drill holes?A proven method is to use tension rods (e.g., telescopic rods) that can be secured between the floor and ceiling, provided the room height is fairly consistent. This offers a stable support without the need for permanent mounting.
Alternatively, there are furniture floor clamps available that secure furniture to the floor using rubber or felt pads, without drilling. These increase friction and reduce the risk of tipping by applying lateral pressure.
Another option is to use heavy bases or platforms on which the PLATSA units can be placed. The increased weight significantly improves stability. You can connect these bases to the modules with simple screws, without putting any strain on the wall.
