ᐅ How can I assemble IKEA PLATSA furniture using fewer screws?
Created on: 16 Mar 2021 08:27
nihat65Hello everyone,
I am currently facing the challenge of assembling several IKEA Platsa furniture pieces and have the question of whether it is possible to use fewer screws during assembly while still achieving stable and secure results.
I understand that IKEA generally specifies a certain number of screws to ensure stability, but especially with larger units, the quantity seems almost excessive to me. I am wondering if there are alternative ways to replace some connecting parts with other techniques or materials, or if it is possible to assemble parts of the PLATSA system with fewer screws without compromising safety or stability.
Perhaps someone here has experience with optimizing material use when assembling PLATSA furniture? Are there any tips or tricks to reduce the number of screws while still obtaining a durable shelf or cabinet unit?
Thank you for your insights and advice!
nihat65 schrieb:
but especially with larger units, the number seems almost excessive to me, and I wonder if there are alternative ways to replace some of the connecting pieces with other techniques or materials, or if the assembly of parts of the PLATSA system can be done with fewer screws without compromising safety or stability.In principle, this is an interesting consideration, but one should not lightly question the specified number of screws recommended by IKEA. IKEA designs its systems so that the loads on the furniture components are optimally distributed. The number of screws is determined by how the material is stressed and the forces expected – not simply based on aesthetics or cost considerations.
That said, there are of course alternative joining methods, such as dowel glue or additional angle brackets, which could potentially eliminate the need for screws. However, I would doubt that fewer screws alone would provide the same level of stability. Such modifications require at least a precise understanding of the material properties and load patterns.
My recommendation: If you want to experiment, test on a sample piece before assembling the entire piece of furniture. For long-term use, caution is advised, as fewer screws almost always mean less safety.
nihat65 schrieb:
Are there any tips for reducing the number of screws while still creating a sturdy shelf or cabinet unit?Hey, the idea of using fewer screws definitely sounds tempting (who wants to screw in 50 screws somewhere 🙄), but I would play it safe! The PLATSA series is known for being quite versatile—maybe you can check if certain modules require fewer screws when the load is kept low.
For example:
- Use stronger back panels or reinforce the backs with wooden boards, as this inherently improves the furniture’s stability.
- Instead of screwing all the joints, you can also use wood glue to securely connect the panels.
This won’t eliminate screws completely, but try identifying the screws that are least critical to stability. I would just proceed step by step. But beware: safety comes first—no one wants their shelf to suddenly collapse 😅.
JORDON schrieb:
But beware: safety comes first – nobody wants their shelf to suddenly collapse 😅.I completely agree. I have also assembled several pieces of PLATSA furniture and can confirm that IKEA’s instructions are there for good reason. Sometimes you want to speed things up or save screws, but the risk of an unstable structure or even accidents is not worth it.
I think anyone who really wants to reduce the number of screws should keep the following points in mind:
- Don’t simply leave out screws that connect load-bearing parts
- Add extra support measures, such as metal brackets or angle connectors, if possible
- Avoid overloading or excessively filling the furniture
You can try to optimize the assembly with fewer screws, but in reality, you will probably only save a minimal amount.
Has anyone had experience with alternative joining methods specifically for PLATSA, such as furniture adhesive or similar? I’m curious whether that has proven effective.
