I’m planning to install a piece of furniture from the Ikea Platsa series in my small guest room. The room is quite compact, so I’m considering how to assemble the units in the best way to make optimal use of the available space. I’m especially interested in the following:
- Are there specific assembly sequences or methods that help save space?
- Which modules work best for small rooms without sacrificing storage capacity?
- Do you have any tips on how to best accommodate the limited dimensions on site when working with larger parts?
I have already looked through the instructions but find them a bit general. If anyone has experience with PLATSA in small rooms or knows useful tricks, I would really appreciate it!
Thank you in advance!
Hello Nopin,
Your concern is quite understandable, as the PLATSA series, due to its modularity, can be both an advantage and a disadvantage for small rooms. Generally, I recommend the following approach:
- Measure the room very carefully and note all important dimensions, especially door openings and any potential obstacles.
- Plan a fixed assembly sequence in advance. For example, start with the lower units first, as they form the base and can later be positioned more easily within the room.
- Consider the depth of the modules. PLATSA units are usually around 35 cm (14 inches) deep, which is suitable for narrow spaces but still requires careful planning.
- Another tip is to assemble the parts lying down first and then place them in the room, in case the access is tight.
Regarding suitable modules, narrow-width carcasses (for example, 40 cm (16 inches)) are ideal for customizing storage space precisely. Wall-mounted and overhead cabinets are also useful for making use of vertical space.
In my own experience with similar room sizes, I found it better to avoid U-shaped PLATSA combinations, as they can visually overwhelm the room. It is preferable to go with a linear layout that allows ample movement space.
I hope this helps you a bit.
Z
zarHenning19 Sep 2022 14:29I would recommend:
- Assemble the modules outside the room before installation.
- Pay attention to the depth; 35cm (14 inches) is standard, anything larger usually won’t fit in small rooms.
- Prefer narrow units (40cm (16 inches) wide).
- Use wall cabinets if floor space is limited.
This way, you can avoid space issues during installation.
Hello Nopin,
I’d like to add my tips since I have completed several PLATSA projects in small guest rooms.
It’s best to sort all parts thoroughly before assembly and first put together the base units completely on the floor. This saves space if you have limited room to work in.
I recommend the narrower carcasses, as they are easier to customize. Additionally, using wall cabinets or shelving units mounted on the walls is a good approach – this makes use of vertical space and keeps the floor clear for movement.
If you have larger modules, assemble them outside the room if possible and bring them in individually. Measure doors and any narrow passages precisely to avoid any snags. It also helps to organize all panels and screws according to a cutting plan.
I also recommend making a sketch before purchase or assembly to try out different layouts. This makes the process more relaxed.
I hope these detailed suggestions are helpful for you.
Nopin schrieb:
Are there specific sequences or procedures during assembly that save space?
Nopin schrieb:
Which modules are especially suitable for small rooms without losing storage space?
Nopin schrieb:
Any tips on how to best handle limited dimensions on site when working with larger parts?
