I want to build a shoe cabinet using IKEA Platsa furniture and have a few questions, as I want to make it as functional and space-saving as possible. Specifically, I’m interested in the following:
- Which PLATSA components are best suited to create a stable and sufficiently deep shoe cabinet?
- How can I best organize the interior to neatly accommodate both flat shoes and boots?
- Are there any special tips for assembly, especially regarding stability if the cabinet is going to be somewhat taller?
- Does anyone use additional inserts or accessories from IKEA that work particularly well for shoes?
I have a hallway width of about 1.8 meters (6 feet) and would ideally like to configure the cabinet so that it doesn’t protrude too much into the room but still offers plenty of storage space.
Thanks in advance for your tips and advice!
FeAndreas130 Apr 2022 19:48Hello klo53,
I can provide some detailed advice regarding your plan to use IKEA PLATSA as a shoe cabinet. First, about the choice of units: The basic modules of the PLATSA series come in different depths – 35 cm (14 inches) is the standard size, which is usually sufficient for shoes, but I would recommend 38 cm (15 inches) or more to easily accommodate bulkier items like winter boots.
Regarding the interior layout: PLATSA offers adjustable shelves, and I would suggest avoiding too many fixed partitions. This way, you can adjust the heights flexibly. For flat shoes, use narrow, multi-tiered shelves, possibly slightly inclined to prevent the shoes from slipping. For boots, consider larger compartments or even integrating a flap door with a fold-out shelf.
Assembly tips: Since PLATSA is relatively lightweight, I would always recommend wall mounting, especially if your cabinet is taller than 1.8 meters (6 feet). Use the included connectors carefully to avoid movement. Also, make sure to place the cabinet on a level surface to ensure stability.
Accessories: IKEA offers special interior inserts and drawers for PLATSA, which you can combine with shoe dividers. It’s also worth looking at the SKUBB shoe boxes as an additional option to stay organized.
I’m also curious about how many pairs of shoes you plan to store and what total storage space you expect, as that would help to give more precise recommendations.
FeAndreas1 schrieb:
I’m still curious about how many pairs of shoes you want to store and the maximum storage space you’re planningThanks for the detailed information. Regarding storage: I own about 20 pairs of shoes, with a fairly broad mix – sneakers, a few dress shoes, some boots, and one or two pairs of sports shoes. The hallway is approximately 1.8 meters (6 feet) wide and narrower in depth (about 1 meter (3 feet)), more depth isn’t possible, so the cabinet depth is the limiting factor.
I prefer a tidy and flexible system without too many fixed shelves so I can rearrange if needed. Stability is important to me, especially for a taller cabinet that could be up to around 2 meters (6.5 feet) high. Is it possible to stack the modules without compromising stability?
Also: how much weight can the shelves support? My concern is that if too many shoes are placed on one shelf, it might eventually sag.
klo53 schrieb:
Is it possible to stack the modules on top of each other without making the cabinet unstable?PLATSA modules can be stacked on top of each other without problems, but there are some limitations: According to IKEA, the maximum height for single-family homes is about 2.5 meters (8 feet 2 inches), and wall anchoring is mandatory. Without anchoring, stability cannot be guaranteed, especially when stacking cabinet units.
The shelves are designed to hold a uniformly distributed load of around 15 kg (33 lbs), which is sufficient for shoes as long as you don’t pile all shoes onto a single shelf. I recommend not overloading the shelves and, if needed, using reinforced center supports – these are available as accessories.
Regarding depth: 35 cm (14 inches) is standard, but there are also 40 cm (16 inches) versions, which are much more practical for shoes. Additionally, using drawers with high sides is worthwhile for stable storage, though this naturally reduces storage space.
In your case, I would suggest a 2x1 meter (6.5 x 3.3 feet) two- or three-section cabinet, about 2 meters (6 feet 6 inches) high, with sturdy wall anchors. The interior layout can be customized – for example, with individual shoe boxes as modular add-ons.
FeAndreas12 May 2022 09:55Benge5 schrieb:
I recommend not overloading the shelves and using the reinforced central supports if needed – these are available as accessories.One more point regarding stability: the reinforced middle supports are indeed a very good option, especially if you plan to store a larger number of heavier shoes. Additionally, if the cabinet is tall, I would make sure to securely fasten the modules with the supplied connectors to prevent tipping.
Another option for your types of shoes are pull-out drawers, which can sometimes be combined with special shoe holders to keep shoes well organized and visible.
Are you planning to install doors on the cabinet or leave it open? Doors are useful in an entryway to reduce dust but can make accessing shoes a bit more difficult.
If you like, I can also provide a sketch with example dimensions and layout suggestions to better tailor the model to your hallway.
