ᐅ How do I install IKEA Metod wall cabinets on a sloped ceiling?
Created on: 26 Jan 2022 10:14
Selobe
I am planning to install IKEA Metod wall cabinets in my attic apartment. I have a question regarding the best way to install these wall cabinets when the wall has a sloped ceiling. In my case, the slope is about 45 degrees, and I want to mount the cabinets so that they are stable and the cabinet fronts align as closely as possible with the main room axis.
Does anyone have experience mounting Metod wall cabinets on a sloped ceiling? What installation options are available, which components or additional solutions are recommended, and what adjustments are needed for the fastenings?
I look forward to any tips, preferably including advice on proper wall fixing or additional supporting structures.
Thank you!
warrenka57
27 Jan 2022 09:18
I still clearly remember how much effort I put into it in my attic. It was a mix of frustration and pride because the sloped ceiling was quite a challenge.
What really helped me was carefully measuring and deciding to use a thicker board as a substructure, securely screwed to the rafters. This allowed me to firmly attach the cabinets, and they have remained stable ever since.
If you’re unsure, take your time during preparation. It’s definitely worth it.
jeff65
27 Jan 2022 11:29
warrenka57 schrieb:
It was somehow a mix of frustration and pride because the slope was definitely a challenge.
The challenge often lies in the fact that Metod profiles are designed for standardized vertical installation. Achieving precise alignment by using a level base platform is a common and reliable solution.
Therefore, I recommend:
- Measuring the slope
- Taking measurements of the fixing points
- Constructing a custom wooden subframe
Many have gained experience with this approach, and the cabinets can then be easily hung without any issues.
Laukau5
28 Jan 2022 08:47
jeff65 schrieb:
The challenge often lies in the fact that the Metod profiles are designed for standardized vertical mounting.
That's correct, and I would like to add: If you don’t want to use a continuous wooden panel, you can also use individual beams as supports.
However, this requires precise planning to ensure that the Metod mounting rail can be properly supported.
Additionally, keep in mind that the mounting rails in the Metod system are designed for a thickness of about 8 mm (0.3 inches). A support structure that is too thick can cause mechanical issues, for example when installing doors or with the cabinet shape on a sloped ceiling.
I also recommend checking any door hinges and handles in advance, as problems often arise with wall cabinets under sloped ceilings due to insufficient clearance.
sarla
28 Jan 2022 09:58
In addition to the previous advice: It is important to carefully check the load-bearing capacity of the sloped ceiling. Sloped ceiling walls are not always made of load-bearing material; they are often constructed with drywall, wood paneling, or directly with rafter cladding.
A fixed wooden beam mounted on the rafters provides the necessary basic stability for the Metod cabinets. Alternatively, a frame structure made of beams can be built and screwed onto the slope.
If the slope is very thin or unstable, I advise against directly mounting the wall cabinets to the slope.
It is also important to level all cabinets horizontally so that the doors close flush and the appearance is correct.
Selobe
29 Jan 2022 10:33
SUBEN60 schrieb:
The Metod cabinet frames have fixed mounting holes designed for a vertical wall. For an angled wall, an adapter bracket is usually required to align the cabinet box properly.
Thank you for the detailed explanations; that helps me a lot!
Regarding the room: The wall is mainly drywall, but there are studs spaced further apart. Does that mean I need to attach the substructure directly to these studs during installation?
Can I build the substructure either from a continuous wooden board or with a frame of beams? Are there any clear advantages or disadvantages to either method?
Also, I’m wondering if the weight of fully loaded wall cabinets (around 3-4 cabinet boxes) can be safely distributed on the studs through the substructure?
Maybe someone has an assessment on this. Thanks in advance!
