ᐅ How do I install Ikea Metod tall cabinets with precise fitting?
Created on: 20 Aug 2023 18:27
Narta66Hello everyone, I am currently facing the challenge of fitting several Ikea Metod tall cabinets precisely against my kitchen wall and have a few questions about it. Specifically, I want to know how to install these cabinets so that the cabinet fronts are truly flush and perfectly aligned, even if the walls are slightly crooked or the floor is not completely level. Are there any special tools or techniques that have proven especially effective for assembling the entire system in a stable and visually flawless way? So far during installation, I have noticed that the cabinets are often slightly offset, and the doors do not close perfectly afterwards. I would also appreciate any tips on adjusting the doors and any tricks for securing the cabinets to the wall. Thanks in advance for your advice!
Narta66 schrieb:
Specifically, I want to know how to install these refrigerators so that the cabinet fronts are perfectly flush and precisely aligned, even if the walls are slightly uneven or the floor isn’t completely level.Hello Narta66, I’m very familiar with this issue, but don’t worry, there are some simple tricks that work really well! 🌟
- The most important thing is to use the adjustable feet to level the cabinets exactly—using a spirit level or bubble level is best.
- If the wall is uneven, you can leave a small gap between the cabinets and the wall, then compensate using wedges or special plastic shims.
- To connect tall cabinets, be sure to use the metal brackets; they provide stability and also help align the fronts evenly.
I would recommend attaching the cabinets loosely to the wall first, then gradually adjust the height and level before tightening all the screws.
Keep at it, it will work! If you want more tips, just ask 🙂
Hello Narta66, I would like to offer some detailed advice regarding your issue, as installing Ikea Metod tall cabinets can be challenging, especially with uneven walls and floors.
First, please consider the following:
- Preparation: Use a precise spirit level to check the floor and walls for unevenness. Mark the areas where adjustment is needed.
- Compensation: The adjustable feet on the cabinets allow you to level out height differences of several centimeters (inches). Adjust the feet so the cabinet stands firmly on the floor.
- Wall mounting: Always use the supplied mounting rails or brackets. Attach the cabinets securely to the wall, but leave the screws a bit loose at first so you can make fine adjustments.
Regarding flush fronts:
- Connect the tall cabinets using the joining brackets, which help keep the cabinets aligned correctly.
- Door adjustment: The Metod cabinet doors have adjustment screws inside that allow you to align the fronts horizontally, vertically, and in depth. This helps compensate for unevenness and prevents the doors from sticking or not closing properly.
An important detail:
- Work systematically from one cabinet to the next, aligning the first cabinet precisely before connecting the next one.
- For slight wall irregularities, it may help to separate the cabinets from the wall using thin spacers, so the fronts remain flush.
I hope these tips make your installation easier. If you have further questions or want a detailed step-by-step guide, feel free to ask.
fredle schrieb:
Door adjustment: The Metod cabinet doors have adjustment screws inside that allow you to align the fronts horizontally, vertically, and in depth.This is really a crucial point that I initially underestimated. I know the feeling when you think everything is properly secured, but then suddenly the doors don’t close properly or appear crooked.
I was relieved that the Metod doors offer so many adjustment options. Sometimes it just takes patience and several small steps until everything fits perfectly.
Additionally, I found it very helpful to check the door alignment again while tightening the connection screws. It can be really frustrating, but it is worth the effort.
How have you or others dealt with crooked walls? For example, I once had a slanted wall that caused minimal gaps – in that situation, wedges were a great help.
koduga schrieb:
How have you or others dealt with uneven walls?I’m happy to explain, as many people face this exact issue.
If the walls are really uneven, I recommend the following approach:
- Measure the wall alignment using a long spirit level or a straightedge to precisely identify where the deviations occur.
- At points with noticeable bulges or recesses, you can attach thin wooden strips or spacers to the wall. These compensate for the difference and create a flat surface for tall cabinets.
- Make sure these strips are securely screwed in and do not wobble.
What’s important for many is that these adjustments affect the entire sightline, so check the straightness of connections and fronts again after installing the strips.
Narta66 schrieb:
I’ve noticed during installation that the cabinets are often slightly misaligned, and the doors don’t close perfectly afterward.That’s completely normal, especially when the walls and floor aren’t perfectly even. The key is to take your time and make adjustments incrementally.
It’s also worthwhile not to tighten the screws on metal brackets too firmly until the cabinets are perfectly level. Otherwise, everything can warp quickly.
If you want, I can also share a rough installation sequence that has proven successful in practice.
TRADI schrieb:
I’m happy to explain, as many people face exactly this question.Thank you, that sounds very helpful! Until now, I hadn’t really considered the idea of leveling the wall first with battens.
fredle schrieb:
Work systematically from one cabinet to the next; first align the first cabinet precisely, then connect the next one to it.I plan to follow that advice, thanks very much for the tip. However, I’m concerned that since I have several tall cabinets along a fairly long wall, I might run into trouble maintaining a continuous alignment.
Does anyone have experience with how to handle a wall that isn’t just crooked but has small irregularities along its entire length that add up?
Would this generally be solved using shims and thin battens, or are there limits where it’s better to install the cabinets with small gaps and adjust the fronts so it doesn’t look off?
