ᐅ How can I install Ikea Metod kitchen units in a space-saving way?
Created on: 16 Jun 2023 08:13
kinsolvi
Good morning everyone, I am planning a new kitchen using Ikea Metod and have some uncertainties about how to design the kitchen layout in the most space-saving way. I’m not only concerned about the overall width or length but also about the optimal arrangement of cabinets and work surfaces to make the best use of the available space.
Specifically, I am interested in:
- Which modules or combinations are especially efficient for small or narrow rooms?
- Are there smart solutions for storage below or above the work surface to keep the kitchen compact?
- What options are available for frequently used elements like the sink and stove, without taking up too much room?
I have done some research, but many tips are quite general. Who has experience with Metod and can offer specific recommendations, including advice on common installation methods or replacing baseboards/ skirting boards that affect usable space? Thanks in advance!
kulau
17 Jun 2023 08:32
Good morning!
Here are some technical notes regarding countertop depth and the overall height of kitchen units:
- Ikea Metod has a standard depth of 60 cm (24 inches). Countertops can be cut modularly without problem, but you must ensure that the sink and stove are precisely adjusted to the new sizes.
- The working height is usually around 91-92 cm (36-36¼ inches) to the top surface of the countertop. If you have adjustable height through modifications to the base or non-standard countertops, keep your height in mind when planning. Ergonomic heights between 86-95 cm (34-37 inches) are possible, depending on the user.
- Taller and narrower wall cabinets save space and create a modern look. Avoid heavy, large wall cabinets in small kitchens, as they can quickly feel overwhelming.
- In very small kitchens, it is worth using the full wall height to create storage up to near the ceiling, but reserve those upper areas mainly for items that are rarely used.
- Consider for yourself: How many people use the kitchen regularly, and how often is it cooked in? This affects the optimal layout and storage use.
If you like, I can provide you with examples to assist in your planning.
kinsolvi
17 Jun 2023 10:15
Thanks to everyone for the valuable feedback; you really helped me organize my thoughts and consider some details I had overlooked.
Regarding the last point from kulau: I mainly cook alone and rarely with a second person, so I don’t need a very large work surface but prefer efficient workflows and storage space for standard kitchen utensils and supplies.
I will use your tips and, during planning, experiment with 50 cm (20 inches) deep options alongside the 60 cm (24 inches) depth, as well as narrower modules and height-adjustable wall cabinets.
If anyone has any final advice on installation, such as common beginner mistakes when assembling the Metod kitchen units, I would appreciate it!
Nabla64
17 Jun 2023 11:01
Two tips to finish:
- Pay close attention to the floor level! Any unevenness should be corrected before assembly; otherwise, doors and drawers may misalign after installation.
- Take your time aligning the modules and only screw them together once everything fits well. Rushing often leads to overlooked small gaps that cause problems later.
If you follow these basic steps, the assembly will go smoothly, and you will be happy with the result.
